Slow 65
Old Nov 23, 2006 | 08:17 PM
412dab's Avatar
412dab
Default Slow 65
I have a 200cid 1965 stang. It isn't fast at all. looking into the possibility/feasiblilty a V8 upgrade or building up the 6cyl.
Old Nov 23, 2006 | 08:28 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Slow 65
Check the FAQ on this site. It will tell you all about it.
Old Nov 23, 2006 | 08:34 PM
412dab's Avatar
412dab
Default RE: Slow 65
Thanks for the prompt reply. Can't expect much from a newbie: I took the time to view all the previous posting and found this info also.
http://www.geocities.com/a65ragtop/V.../i6_to_v8.html
Old Nov 23, 2006 | 08:35 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Slow 65
If you wanted a fast car, why did you buy the 6 banger in the first place? The 6 cylinder engine can be built up cheaper than going to a small block V8. Check with these guys.
www.fordsix.com
Old Nov 23, 2006 | 08:47 PM
BakoLuke's Avatar
BakoLuke
Default RE: Slow 65
ORIGINAL: Soaring
www.fordsix.com
+1
Old Nov 23, 2006 | 08:51 PM
EmperorOfChicken's Avatar
EmperorOfChicken
Default RE: Slow 65
you can turbo a six, but if you REALLY wanted POWER id get a 347 stroker and a shot of n2o.
Old Nov 23, 2006 | 11:24 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: Slow 65
Yeah you can build a 6, but a V8 has more potential. the problem is swapping a V8 in will cost as much as building up the 6, but if you want serious power (like 11s or faster) the bigger engine will do it easier. Either way, if you make more power, you will be changing rear ends, brakes, and other parts of the V8 swap even if you stay with the 6.
Whatever works, some people like the 6. In the end its up to you really.
4cylinderplus2
Oct 9, 2020 07:45 PM
KingRando
Oct 1, 2015 11:16 AM
RCS02v6
Sep 29, 2015 01:46 PM
3.0Taurass
Sep 20, 2015 08:06 PM
