Rear Quarters
Old Nov 24, 2006 | 06:50 PM
rustycoupe's Avatar
rustycoupe
Default Rear Quarters
Hey guys,
I've got some pretty nasty looking rear quarters and was wondering if I needed just the skins or the full quarter.
I don't understand the difference. Both of mine had an inch of bondo around the flare and crappy patches behind the wheel.
Thanks
Here are some pics
http://i122.photobucket.com/albums/o...Picture001.jpg
http://i122.photobucket.com/albums/o...Picture004.jpg
http://i122.photobucket.com/albums/o...Picture003.jpg
http://i122.photobucket.com/albums/o...Picture002.jpg
Old Nov 24, 2006 | 06:58 PM
P Zero's Avatar
P Zero
Default RE: Rear Quarters
A whole 1/4 panel is not only the outer skin but the structural stuff as well, usually to install a complete 1/4 you might even have to cut into the roof. And the skin is just the outer sheet metal, no strutural stuff underneath.
-P.
PS: Installing a complete 1/4 is VERy timeconsuming and pretty damn expensive. Installing a skin isnt as much,its not cheap.
Old Nov 25, 2006 | 12:58 PM
rustycoupe's Avatar
rustycoupe
ahhh bump..i need help badly.
Old Nov 25, 2006 | 03:50 PM
Soaring's Avatar
Soaring
I ♥ Acer
The rear quarter is one piece of metal......no skin. So, you are going to have to replace the entire quarter panel. I think I have an article in the FAQ about how to replace it. It is not something a novice should tackle.
Old Nov 25, 2006 | 05:08 PM
paddy187's Avatar
paddy187
you can get skins for rear quaters if you get away with it, i think that you might need rear quaters but I am guessing rather than speaking from knowledge, soz i can't help
Old Nov 25, 2006 | 06:42 PM
KStang65's Avatar
KStang65
My 65 coupe was hit in the passenger quarter panel. Not realizing exactly what was included with the NPD full face repair panel (skin), I picked up a full quarter panel for the passenger side and a skin for the driver side.
The only difference was the outside tail light panel is not included with the skin and it only has about 2 inches of metal on the top edge. The full quarter panel includes the outside tail light panel and the rest of the top edge including the trunk lip and the part that welds up to the roof.
Had I known I would have gone with the repair panel only since the rest of the metal is good. The full quarter cost double the repair panel.
Depending upon how original you want it and how good the rest of the metal is, you should be able to go with either.
Old Nov 25, 2006 | 06:49 PM
valley firearms's Avatar
valley firearms
When the rust looks like that, the problem will go deeper as well. You need to check your wheel housings, rocker panels, rear torque boxes, trunk area. Just because it looks good from the outside it may be a mess inside. It will rust from the inside out. Unfortunately many people patch things up to find their nice paint job bubbling with rust a year or two later. They don't call rust cancer for nothing. If you weld in patch panels to make it look good it will continue to rust.
Old Nov 25, 2006 | 07:15 PM
Soaring's Avatar
Soaring
I ♥ Acer
When you say rear quarter panel, you are talking about one piece of metal. There are other names for all the other stuff.
Old Nov 26, 2006 | 07:51 PM
moparmatt89's Avatar
moparmatt89
I would go with the skin, i had real bad quarters that were just as bad as yours and i just welded on some new skins. You cant even tell they were replaced even from the inside. Your quarters look pretty nice and solid on top so ther is no snese touching that good metal. It took about 3 hrs per side to take out the old one line up and weld the new ones in.
Matt
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
b8checker
Sep 30, 2015 07:11 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
