c4 to AOD
Old Nov 27, 2006 | 12:47 AM
eZ's Avatar
eZ
Default c4 to AOD
i swapped out my c4 for a street-strip AOD, does anyone make a shift linkage or do i have to fabricate one for my 65?
thanks,
Dan
Old Nov 27, 2006 | 02:27 AM
Scott H.'s Avatar
Scott H.
Default RE: c4 to AOD
Hi Dan,
Try a search on this. I'm sure I've read where someone either fabricated or bought the linkage piece you are talking about. Might have been on another forum though.
Cool idea to to keep the stock shifter. Good luck with it.
Old Nov 27, 2006 | 01:51 PM
85lebaront2's Avatar
85lebaront2
Lokar makes linkage for anything, real nice stuff too. I have used it on a customer's 55 Dodge pickup street rod.
Old Nov 27, 2006 | 02:02 PM
eZ's Avatar
eZ
do you think this is it?
http://www.mustangsplus.com/Merchant...Code=new_items
Old Nov 27, 2006 | 02:23 PM
eZ's Avatar
eZ
Lokar did not have it
Old Nov 27, 2006 | 02:30 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
ya i think that is the one that you want
Old Nov 27, 2006 | 11:42 PM
LCC's Avatar
LCC
Thats the one for your original shiffter. Don't forget you need a TV cable to adjust line pressure in the trans. Lokar also makes this and its easy to setup..
Old Nov 28, 2006 | 12:04 AM
eZ's Avatar
eZ
LCC
i know nothing about the TV cable...this is the first transmission work ive ever done...is it something a newb can do?
Old Nov 28, 2006 | 12:18 AM
LCC's Avatar
LCC
All AOD's need a throttle velocity cable connected to the carb from the trans. The lokar kit is the same I used and it was easy. If you don't put one in you will burn the clutchs out of your trans in about 15 to 30 min of driving.
Old Nov 28, 2006 | 03:20 AM
Brandontyler65
I ♥ Acer
and it has to be set just right or it won't drive right
