Locked diff(minispool) Drivability??
Old Nov 28, 2006 | 01:27 AM
atomsk680's Avatar
atomsk680
Default RE: Locked diff(minispool) Drivability??
im going to order soo a detroit trutrac locker, i need it, i get all the way up to the point to submit order, but the numbers are so $&^$&^ing high, i jsut cant, i need to take a few shots and order it.[&:]
Old Nov 28, 2006 | 01:34 AM
Aussie66Fastback's Avatar
Aussie66Fastback
how much are they over there?
we took the 9" center from the rally car in to the diff guy and the parts I think were $aussie 750 and labour about $400 or so to fit up and reinstall in the car.
I want one too...man they are so good to drive on compared to open, LSD (posi?), full spool, fake spool (welded gears) or Torsen.
Old Nov 28, 2006 | 04:20 AM
atomsk680's Avatar
atomsk680
ORIGINAL: Aussie66Fastback
there around $500 but i can only find them for 8.8 an 9 inch on summit
wow
thats not a bad price
http://www.andale.com/stores/sf_item...0461892&mode=1
Old Nov 28, 2006 | 03:38 PM
atomsk680's Avatar
atomsk680
bump
Old Nov 28, 2006 | 04:44 PM
whoafrdofdapolce's Avatar
whoafrdofdapolce
do youself a favor and never consider a spool again. i got one because i thought it would be fun for burnouts but the weak sub frames cant handel the preshure the spool puts on the car and my paint started cracking all over the place. i destroied my new leaf springs i just put in also. i eventchely traded my 3.75 geard spool for a stock geard open end because i wanted to be able to drive my car again.
Old Nov 28, 2006 | 07:32 PM
Yonco's Avatar
Yonco
well, first off... build a car that can handle it... a 71 is a unibody... you really have to TIE THE FRAME with atleast 2 bars going from the front unibody frame to the rear one, them throw an X inbetween. And some added supports between the unibidy rails wouldnt hurt. -Jon
Old Nov 28, 2006 | 08:46 PM
LCC's Avatar
LCC
I am asuming that your horsepower is not in the 300's or more so having a frame problem isn't an issue right now. When you do get to that point you can spend the money on connecting the sub frame because you'll already have the locker...[sm=gears.gif]
Old Nov 28, 2006 | 10:56 PM
Decurion's Avatar
Decurion
something that is held in high regards in the 4x4 community, but doesnt get the time of day on the street is a selectable locker. They can be electric or air operated, but when they are off they act like a standard open or posi rear, and when switched on, they act like a full spool. Theyre a little pricey at $850+ said and done, but it would be the ultimate in traction in a straight line, without sacificing anything on the street.
Old Nov 28, 2006 | 11:12 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Try Currie. Looks like a couple Benji's will get you pretty close to a trak-lok.
ORIGINAL: atomsk680
wow
Old Nov 29, 2006 | 12:48 AM
Scott H.'s Avatar
Scott H.
I found mine (True-trac for 8.8" 31 spline) for $354.00 +$21.57 shipping to Northern California. That was Sept, '05, but you might check them out. Drive Train Specialists Seemed like nice people. They called the next morning confirming my internet order, and making sure all the information was correct. I thought that was nice service and pretty smart on their part.
Edit************
Almost forgot...Pay attention to the pin size. For the same price I picked up the chunk with the larger 7/8" pin.
Good luck,
BOB ROME
Jul 26, 2023 01:54 PM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
Sep 25, 2015 06:58 PM
Sep 24, 2015 09:18 PM
