gasket dressing...
Old Dec 6, 2006 | 09:03 AM
jes72mustang's Avatar
jes72mustang
Default gasket dressing...
I am hoping to install my headers this evening. I was just trying to figure out if I should use gasket dressing on the gasket or not. I am talking about the blue permatex stuff it has a name that starts with an "H". IT says for exhaust manifold gaskets on it. SHould I use this or install the gaskets dry?
Thanks
Old Dec 6, 2006 | 09:09 AM
supermanzx9r's Avatar
supermanzx9r
Default RE: gasket dressing...
i use only a little on each corner to help it stay put when installing
Old Dec 6, 2006 | 11:34 AM
Hornblower's Avatar
Hornblower
I ♥ Acer
Header gaskets go on dry.
Old Dec 6, 2006 | 02:06 PM
coda618's Avatar
coda618
+1 on the dry gaskets. Also, get a little tube of thread locker (medium duty) and put a dab on each bolt. Help keep teh header bolts from backing out, as the are prone to do.
Old Dec 6, 2006 | 02:46 PM
gothand's Avatar
gothand
ORIGINAL: coda618
FYI, if the heads are aluminum, do not use thread lock, but definitely use anti-seize on the header bolts, spark plugs and anything else that threads into the heads.
Old Dec 6, 2006 | 03:28 PM
coda618's Avatar
coda618
Thanks for the tip, you learn something new everyday. Hopefully one day I will be able to afford aluminum heads so that I may make use of this tidbit.
Old Dec 6, 2006 | 03:44 PM
gothand's Avatar
gothand
I have aluminum beadlock wheels on my Jeep with 24 bolts per wheel. I use anti-seize like it is going out of style. Fortunately, I learned of the anti-seize long before getting them, but I do recall learning the hard way on something else. Oops.
BTW, if the headers are coming loose, the 'anti-loosen' bolt kit (don't remember the name) for about $40 works pretty well, however, you may damage some of the locking washers when you remove them if they've been on the vehicle for awhile and have any rust. [:'(]
Old Dec 6, 2006 | 03:56 PM
supermanzx9r
sorry i was told that when i went to auto school (lincoln tech ) to use it to help hold it in place only a little like wiping glue on paper very thin ...... but oh well maybe i was told wrong
Oct 26, 2015 05:01 PM
Dathan
Oct 5, 2015 05:52 AM
wraith777
Sep 28, 2015 10:49 AM
Demodulates
Sep 18, 2015 11:14 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
