lug nut size
Old Dec 9, 2006 | 11:03 PM
moparmatt89's Avatar
moparmatt89
Default lug nut size
does anyone know the lug nut size for a 69 mustang with a 8 inch rear end. I believe that it is 1/2 but i want to double check. I need to know this because i am getting new custom alloy axles and i need to know the size of the studs i should use. Also what would you all recommend screw in or press in studs?
Matt
Old Dec 9, 2006 | 11:06 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: lug nut size
yeah 1/2" and you can do fine with press in studs. Screw in are okay, but as long as you have quality studs dont worry about them. You arent making enough power to break anything unless a wheel is loose.
Old Dec 9, 2006 | 11:09 PM
moparmatt89
ok, thanks alot
Old Dec 9, 2006 | 11:15 PM
moparmatt89
also would anyone happen to know what housing end type is? i posted the link below to show you the form i have to fill out. It asks what housing end type it is, i believe it is the one that says small ford but i am not positive. I have an 8 inch rear
matt
http://static.summitracing.com/globa...der%20form.pdf
RCS02v6
Sep 29, 2015 01:46 PM
Sep 25, 2015 06:58 PM
Sep 25, 2015 06:42 PM
