new sway bars
Old Dec 10, 2006 | 02:54 PM
jroseman's Avatar
jroseman
Default new sway bars
just installed a 1 inch addco sway bar in the front and a 3/4 inch in the rear. man does it stiffen the car up.
Old Dec 10, 2006 | 03:00 PM
69mach1377's Avatar
69mach1377
Default RE: new sway bars
Especially if you have lots of torque. Mine reacted violently without the rear installed.
Old Dec 10, 2006 | 04:29 PM
baddog671's Avatar
baddog671
I bought some the other week but havent installed yet. Cant wait
Old Dec 10, 2006 | 07:52 PM
jroseman's Avatar
jroseman
it really makes a difference in the ride. a little less smooth but the car stays flat on curves.
Old Dec 10, 2006 | 08:49 PM
Gun Jam's Avatar
Gun Jam
I wouldn’t drive mine without them.
A Warning however: Avoid jacking the car from one side as it adds undue strain on the system. I had to reinforce mine where they bolted to the frame as the bolts pulled through the metal of the frame.
Old Dec 10, 2006 | 09:13 PM
atomsk680's Avatar
atomsk680
im getting the chasiss stiffening kit for xmas! cant wait.
Old Dec 10, 2006 | 09:51 PM
jroseman's Avatar
jroseman
thanks for the info. any more things i need to be aware of?
Old Dec 10, 2006 | 10:41 PM
THUMPIN455's Avatar
THUMPIN455
it will now slide easier on wet and icy surfaces!
but its much more controllable...
Old Dec 11, 2006 | 02:31 AM
baddog671's Avatar
baddog671
A quick question of ignorance...
Obviously you can have a very loose ride, a normal loose ride, stiff ride, etc... but can you get too stiff? How would that effect your cars suspension, handing and steering, etc? I already have weld in subframe connecters, export brace, new sways, soon to be carlo bar, and the like....
Old Dec 11, 2006 | 03:00 AM
2bav8's Avatar
2bav8
Yes your suspension can be too stiff.
Too stiff up front and your suspension may be prone to understeer.
Too stiff in the back and the car may be prone to oversteer.
