front end help *update*
Old Dec 13, 2006 | 05:33 AM
Lumbergh's Avatar
Lumbergh
Default RE: front end help *update*
I recommend asking at a classic car club, classic Mustangs if possible, in your area for the best recommendations for an alignment shop. One thing that I can pretty much guarantee is that none of the chain shops will be able to do it correctly. I wouldn't want to rely on the alignment shop being honest about their ability to do the job, if I could avoid it. Regarding the Shelby drop, you will probably need to give the alignment shop the new specs as they are different from the factory alignment specs. I believe that Decurion gave the specs. I assume they are the correct ones, but wouldn't know for sure wihtout checking. Depending on the year of your Mustang, the shop may or may not need the shims that Soaring mentioned. I believe that they were only used on the 65 and 66 Mustangs.
Old Dec 13, 2006 | 05:41 AM
baddog671's Avatar
baddog671
eZ, were you the one that bought the front end kit from laurelmountainmustang? My kit included the front,rear, and steering pieces but I deleted the steering to save 122 bucks. I already replaced it last year. I believe their steering kit is about 145, so check it out.
Old Dec 13, 2006 | 02:27 PM
eZ's Avatar
eZ
i know a pretty good alignment shop...ill keep the specs to give to them. as far as the steering i wont be able to buy all that right now. just got laid off yesterday so money will be tight. luckily i have already bought almost everything i need to get the car running
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
the5
Sep 19, 2015 06:13 PM
Sparks_88
Sep 8, 2015 01:06 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
