power steering diy
Old Dec 15, 2006 | 09:24 AM
supermanzx9r's Avatar
supermanzx9r
Default power steering diy
is there a way for me to just buy the parts to make my own power steering setup with out giving up an arm or a leg , if someonecan come up with the idea of the granada brake conversion i know there has to be a car guru in the forum with the answer to my question
Old Dec 15, 2006 | 09:32 AM
supermanzx9r
Default RE: power steering diy
if i got the power steering pump and bracket from autozone for 100.00 total and this kit http://store.summitracing.com/egnsea...5&autoview=sku and some hoses will this be everything i will need to pull off a cheap a power steering conversion
Old Dec 15, 2006 | 02:59 PM
Gun Jam's Avatar
Gun Jam
Ah you missed out I just sold my entire PS system minus the drag link on ebay.
The stuff in that link is good but new so it cost a lot. Look for that valve at a junkyard or ebay as they are bullet proof and any thing that does fail in them can be replaced for about 20.00 (and should be before you install it)
The pump went for about 150.00 bucks on ebay in good working order.
The valve brought in about 70.00 but was gutted and needed a rebuild kit (another 20 bucks)
Look around you should be able to find lots of options.
Gun
Old Dec 15, 2006 | 03:21 PM
supermanzx9r
i am cool with the prices i have so far i just need a full list of everything i need to do a conversion from manual to power steering in my 67 stang
Old Dec 18, 2006 | 08:23 AM
supermanzx9r
can some one pls give me a full list of everything i need to do a conversion from manual to power steering in my 67 stang with a 289 engine
Old Dec 18, 2006 | 01:37 PM
highhilleer's Avatar
highhilleer
A couple of suggestions, read the excellent information at
http://www.stangerssite.com/
Down load the NPD catalogue (npdlink.com) and do a side by side comparisom of the part numbers for the power and standard steering systems. This is the best way I know of to get a complete list of the different parts. Be careful with the 67 some have steering systems like the 66 and some are like the 68. If you have a "rag" joint in the steering column you are fortunate and have the 68 style.
I bought a complete used system and sent the moving parts to the guy at the stangersite for reconditioning. Excellent workmanship. Of course, I think this is the best way to go.... However, with hind site, I'm wishing I had evaluated using one of the replacement rack and pinion systems for not much more money. Just something to think about.
Good luck
Old Dec 18, 2006 | 02:51 PM
supermanzx9r
i found a setup on ebay thank you eveybody for your help
CS2007
Jun 25, 2019 09:45 PM
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
Sep 25, 2015 06:58 PM
