Flickering Headlights
Old Dec 16, 2006 | 10:04 PM
unit91's Avatar
unit91
Default Flickering Headlights
Headlights flicker at a prety steady tempo while driving. Any ideas?
Old Dec 16, 2006 | 10:09 PM
bignatesan's Avatar
bignatesan
Default RE: Flickering Headlights
Maybe a bad ground somewhere.
Old Dec 16, 2006 | 10:55 PM
mustanglover66's Avatar
mustanglover66
check the ground wires atached to the headlights
Old Dec 17, 2006 | 12:04 AM
valley firearms's Avatar
valley firearms
Those old wires get hard over the years and the insulation on the outside crack. It may be a short or bad ground as the others have stated.
Old Dec 17, 2006 | 12:10 AM
unit91's Avatar
unit91
OK.....will do. Do you know if there's a way to answer more than one reply at the same time?
Old Dec 17, 2006 | 12:12 AM
Halz5's Avatar
Halz5
Couldnt a bad voltage regulator cause that or no?
Old Dec 17, 2006 | 12:16 AM
unit91's Avatar
unit91
Could be. How about alternator/regulator or loose belt?
rmodel65's Avatar
rmodel65
Yukon Cornelius
are u running halogens? sometimes they can cause the switch to overload and make the circuit protection to open
Old Dec 17, 2006 | 12:17 AM
unit91's Avatar
unit91
Nope......just regular bulbs......
Old Dec 17, 2006 | 02:45 AM
stanging's Avatar
stanging
Need a new head light switch, which I believe is also a circuit breaker on early mustangs.
