Pulling engine and tranny
Old Dec 18, 2006 | 10:54 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Pulling engine and tranny
>>>>>You do need to drain the antifreeze but not the engine and tranny if you don't want to. <<<<<<<<
Let's try to be as accurate in our responses as we can be. I know I have made mistakes like this also. Nobody is perfect on here, and that includes everybody.
Old Dec 19, 2006 | 02:29 AM
bronco1's Avatar
bronco1
Drain all that you can. Anything you can do to make it lighter and less messy is good...and more safe.
Old Dec 19, 2006 | 02:39 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Definitely drain the fluids. FYI, you can drain the fluid out of a manual without a pump. The lowest bolt on the tailshaft housing doubles as the drain. (Toploaders anyway...only know about good trannies)
Old Dec 19, 2006 | 02:49 AM
ford65stang's Avatar
ford65stang
yea.......that tranny fuild is terrible......it will drain from the the input of the drive shaft......i had alot of cleaning up to do....
if you remove the fan it should give you a few more inches to play with trying to get it out.....
i did use the kitty litter.... there were about 8 kittens in the litter i used, they played in the tranny fuild and then i cleaned them up using Dawn kitchen soap. [sm=joke.gif] [sm=smiley36.gif]
i used the cheapest kitter litter and mixed it with some cheap dry soap (kinda like biz) they worked well together....but it still works great without the soap
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
