c-4 rebuild question
I emailed dynamic and asked for a price and parts list on a rebuild kit and they told me for $225 I get "All your gaskets, seals, Teflon Rings for the pump, Kolene heat-treated steels for Direct (6-clutch Power pack w/Red Eagle friction), 5 steels and BW friction for Forward,extra wide babbit bushings for pump and ext. housing, Kevlar Int. band- everything we use to do a full freshen up on a Mighty Mite." Is there anything else I'm going to need to have this job done? it's a stock c-4 from a 69 stang and I know about the convertor and bell housing. anything else that I'll need for internals?
Get a decent 2-3'rd servo and you'll probably need a replacement pin for the Modulator. May even get a new Mod valve if the current one is not new.
Get a good neopreme pan gasket as well. I dislike the cork type.
treesloth
Sep 28, 2015 07:03 AM
