power steering and water pump
Is it ok to start my car with power steering belt off? The car is on blocks so it isn't going anywhere. Also, do I have to drain anything to change the water pump? Thanks again.
Your car will run fine without the power steering pump. But, the water pump is driven by the same belt, which you will need after, say, 5-10 seconds to avoid hot spots.
You'll want to drain the power steering fluid before removing the pump. It wouldn't be a bad idea to flush the fluid whil you're at it.
uberstang1
Sep 20, 2015 06:42 PM
jaiidutch
Sep 14, 2015 10:29 AM
