getting the 9" together
Old Dec 27, 2006 | 02:07 AM
valley firearms's Avatar
valley firearms
Default getting the 9" together
I cut the ladder bars off today and cleaned up the torch cuts with a grinder. The rear was rusted pretty bad as is everything left out in the elements in Alaska. I then went over the whole housing with a wire cup on a grinder. I will weld up some pits left by the PO who welded the ladder bars on. JR at Alaska axle is rebuilding the third member for me. I went over there today and looked at everything. He said everything looked great. It is a factory limited slip with 3.00 gears. He is going to replace the clutches, seals, and bearings. Then he is going to put 4:11's in there at my request. He thinks I should go 3:73. After I clean up the housing a little more it will be sandblasted and powder coated. I'm thinking black but I also think silver would be cool. What do you all think? Here is a pic of before and after.
[align=left] [/align]
[IMG]local://upfiles/21693/D8C92746FE5E4A4DB589345D6E9EB14B.jpg[/IMG]
[IMG]local://upfiles/21693/9E4DF3B6610E4AFC8C85F1AFC0903EF8.jpg[/IMG]
Old Dec 27, 2006 | 02:47 AM
68SCode4speed's Avatar
68SCode4speed
Default RE: getting the 9" together
Hit it with a primer/sealer - I like Duplicolor, good stuff... Then Duplicolor rattle can it - can't go wrong with black but silver would be cool looking too. Either way it will look good.
Old Dec 27, 2006 | 12:06 PM
Kingoftheroad's Avatar
Kingoftheroad
What transmission do you have?
I just powder coated my rear axel a couple days ago. Looks verry nice.I got a black color. I also powdercoated the drum brakes and some other parts for the axel. Im looking forwart to puting the pices back together.
Old Dec 27, 2006 | 03:13 PM
valley firearms
Hello KR,
I will have a top loader with wide ratio gearing. Did you do the powdercoating yourself? I have heard of kits being available.
Old Dec 27, 2006 | 05:45 PM
Kingoftheroad
NoI did not do it my self. A company did it for me. Remember that if you are going to powder coat large pices you need a pretty big oven. But for small pices i think the kit is an investment. There are a lot of pices that could need som powdercoat on a old car.
