My door doesn't shut very well.
Old Dec 29, 2006 | 05:45 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: My door doesn't shut very well.
wd40 isnt really a lube is actually a water dispersant its water disp formula 40
Old Dec 29, 2006 | 05:54 AM
Soaring's Avatar
Soaring
I ♥ Acer
OK guys.....I have had lithium grease on the catch and mechanism from the get-go. It appears to me that the catch may have a groove in it, and the latch is having a hard time grabbing the catch. Take a look at these pics, and tell me what you think. Can I just adjust the catch, or do I need to replace it?
[IMG]local://upfiles/10034/7CE0E0D05AEB4CD58C9D256F55DA0A90.jpg[/IMG]
[IMG]local://upfiles/10034/3E27C9F332754DF1ABC10BB7C29AD10F.jpg[/IMG]
On Edit:
I just now went out and inspected the latch and catch more closely. The catch does not have a groove in it. (3rd pic) It is perfectly round and appears to be just fine. So, now I am suspecting the latch. I just may have to tear into it to see about the spring thing as mentioned.
[IMG]local://upfiles/10034/82B7F75D941840E8AF602B9DA21D88C8.jpg[/IMG]
Old Dec 29, 2006 | 12:38 PM
andrewmp6's Avatar
andrewmp6
might need a new latch as long as the door hasnt sagged
Old Dec 29, 2006 | 12:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
No, the door doesn't sag. Must be the latch. Thanks.....
Old Dec 29, 2006 | 02:28 PM
Scott H.'s Avatar
Scott H.
Old Dec 29, 2006 | 02:34 PM
THUMPIN455's Avatar
THUMPIN455
I am with Scott.. It doesnt take much to pull the door panel, unbolt the latch, clean and lube it real well, then put it back.
You have the time to do it Glen, just do it.
Old Dec 29, 2006 | 08:10 PM
Colorado_Mustang's Avatar
Colorado_Mustang
WD40 is better at cleaning away the old goo and allowing the mechanism to work again. You could use brake cleaner, but WD40, and its competition, are safer to use around painted parts.
ORIGINAL: 19stang66
Lithium grease is a better lubricant that wd-40 in the long run.
Old Dec 29, 2006 | 08:18 PM
19stang66's Avatar
19stang66
It all makes sense now
Old Dec 30, 2006 | 01:56 AM
valley firearms's Avatar
valley firearms
Soaring, old yeller is getting old just like you and me. I always say, rub a little grease on it and it will work fine[8D]. Of course you should clean it like the others have said.
[align=left] [/align]
Old Dec 30, 2006 | 04:03 AM
andrewmp6's Avatar
andrewmp6
after looking closer at the pictures scott is right your striker has moved see the bare paint spot
