pitman arm
Old Dec 29, 2006 | 03:10 PM
eZ's Avatar
eZ
Default pitman arm
i have a 65 mustang that ive converted to a v8 from the i6. i just received the new centerlink. problem im running into is on the i6 the centerlink attached to the pitman arm and the innner tie rod also attached to the pitman arm. can i use the existing i6 pitman arm and leave the other hole empty where the inner tie rod used to go?
[/align]
Old Dec 29, 2006 | 04:18 PM
coda618's Avatar
coda618
Default RE: pitman arm
Not positive, but I believe it is a different arm. Don't know about using the same one.
Old Dec 29, 2006 | 06:00 PM
JamesW's Avatar
JamesW
The draglink and the pitman arm are different between the I6 and V8 steering. The V8 pitman arm has one hole and attaches to the draglink. The draglink then attached to the inner tie rod.
Here's the V8 drag link (Center Steering Link)
Here's the I6 center link
Here's the V8 Pitman Arm
guitarman376
Oct 11, 2015 01:47 AM
UrS4
Oct 3, 2015 06:23 AM
UrS4
Sep 30, 2015 10:13 AM
03blackwidow
Sep 20, 2015 02:36 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
