Dash Bezel replacements
Old Dec 30, 2006 | 05:52 PM
az289must's Avatar
az289must
Default Dash Bezel replacements
Help, I'm trying to replace my ignition dash bezel and wiper dash bezel on a 65 convertible. I put the key in the ignition, inserted a paper clip into the small hole below the ignition and turned the key to ACC, but the tumbler will not come out. My book says I just need to pull on the key as I turn it and the tumbler should come out. Any suggestions? Also, how do I remove the wiper **** to get to the bezel? Any help is appreciated!
Old Dec 30, 2006 | 08:13 PM
69stangcoupe's Avatar
69stangcoupe
Default RE: Dash Bezel replacements
on my 69 it was kind of tricky but just be patient and try again and it will come out. good luck
Old Dec 30, 2006 | 11:39 PM
stang6790's Avatar
stang6790
I think you have to turn it to accessory then insert the paperclip and then it will turn on past accessory and at that point you should be able to pull it out.
Old Dec 31, 2006 | 12:42 AM
middiepride's Avatar
middiepride
jiggle the **** out of it until it comes out.
Old Dec 31, 2006 | 07:57 PM
az289must's Avatar
az289must
Thanks for the info. I removed the tumbler but had to install a new ignition switch because I damaged it when I removed the bezel. I'm having a difficult time attaching the bezel to the switch. Is there a secret on how to line up everything? My hand is killing me from trying to push on the back of the switch from underneath the dash and lining up everything!!!!! If anyone knows of an easier way to do it, please help!
Old Dec 31, 2006 | 08:35 PM
stangimgood's Avatar
stangimgood
i remember doing that!!! used a heavy leather glove and a shop rag....i know there must be better way out there someplace but haven't heard it yet..........
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
tmdm
Sep 4, 2015 06:45 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
iamgobono
Sep 3, 2015 12:37 PM
