Choke Question
Old Dec 30, 2006 | 06:46 PM
MrMainEvent24's Avatar
MrMainEvent24
Default Choke Question
What should the automatic choke be set at on a 1964.5 Coupe 289 4V (D Code)?
When it is cold it is reving at 2200 rpms? What should it be changed to??
Thanks
Old Dec 30, 2006 | 07:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Choke Question
The butterfly should be completely closed when the engine is cold. Tap the accelerator and take the air cleaner off and see if the butterfly is closed. If not. then loosen the three small screws and turn the black hub until it is.
Old Dec 30, 2006 | 08:55 PM
MrMainEvent24
Do you know what the rpms should be at when started cold?
Old Dec 30, 2006 | 09:22 PM
thunderize's Avatar
thunderize
The choke on mine does not want to close all the way even with pressure. Seems like the rod connected to the butterflys does not move freely. I can adjust the choke to open more but not close all the way.
Old Dec 30, 2006 | 10:19 PM
ponyx2's Avatar
ponyx2
It is supposed to close within 1/4 of an inch +/- stone cold, push the accelerator to the floor once. If not, turn the black bakelite housing one way or the other to acheive the 1/4".
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
