need help A.S.A.P.!!
Old Dec 31, 2006 | 04:11 PM
ADRIAN1's Avatar
ADRIAN1
Default need help A.S.A.P.!!
i need to know where my starter is located so i can take it off and buy a new one and install it by today. I have to get my car running by tonight so this needs to be done very very soon! please post pics so i can take it off faster! thanks!!!!!!!!!!
Old Dec 31, 2006 | 04:16 PM
Clu7ch's Avatar
Clu7ch
Default RE: need help A.S.A.P.!!
It should be butted up against the tranny near the bottom of the motor. I can't say which side it's on for wure, but you should be able to see it. Best bet, follow your wires off of the solinoid down to the starter.
Old Dec 31, 2006 | 04:33 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Passenger side on the bottom. Two bolts and the power wire and it's out. (9/16" and 1/2" IIRC)
Old Dec 31, 2006 | 04:55 PM
JamesW's Avatar
JamesW
This is from behind the pass front tire. It's up between the header and the oilpan...mounted to the transmission bellhousing.
Be sure to take it with you for 1) them to test and 2) to make sure you get one identical. Put a new cable on it (from the starter to the solenoid) while you're under there.
Old Dec 31, 2006 | 11:21 PM
ADRIAN1's Avatar
ADRIAN1
thanks guys. everything worked out fine! now im installing my MSD but i need to know the timing... please post if you know! thanks
Shadow16508
3.7L V6 Technical Discussions
Jun 24, 2012 12:48 PM
Bjiscuit
19
Mar 2, 2012 06:07 PM
bakerjd
Dec 5, 2011 04:12 PM
2007_Stang
Oct 18, 2008 03:08 PM
