Unbelievable
Old Jan 4, 2007 | 11:42 AM
jrrhd73must's Avatar
jrrhd73must
Default Unbelievable
So I pick up this 67 Cougar, that I am planning on restoring. I can not get the stupid thing to start, so I start tracing wires and find a push butten switch wired directly to the starter under the dash, so I think to myself this thing is going to be a wiring nightmare.
Now here is the really funny part.....
My 15 year old daughter comes over, the car is going to be hers, and sits in the car. So I tell her to put on the emergency brake, since the car is going to sit at the end of my driveway for a while. She tells me Daddy something just squirted on the windsheild, and the brake won't stay in. I told her to do it again, and again the same results. I checked the brake the guy built a manual pump and used the emergency brake pedal to pump windsheild wiper fluid on the windshield....Unbelievable [sm=bangbang.gif]
Old Jan 4, 2007 | 11:48 AM
S281SC's Avatar
S281SC
Default RE: Unbelievable
Not quite...
The 67 Cougar/Mustang had a hand "pull-type" e-brake handle mounted to the bottom of the dash. They also used a foot pump for the windshield washers. Sounds like she actually hit the windshield washer foot pump and the hose is disconnected... [&:] Blame this one on Ford's design, not a previous owner mod!
Old Jan 4, 2007 | 11:53 AM
Grimm's Avatar
Grimm
Come on. It was only 2k with little rust. Did you really think you would get off that easily?
Old Jan 4, 2007 | 11:54 AM
jrrhd73must
Well I'll be, I had no idea..There you go I guess I am the one that is ignorant....Holy cow...
Old Jan 4, 2007 | 12:10 PM
grruminator78's Avatar
grruminator78
That's okay, the lines were all cut when I got my 67, but the PO thought the pedal was installed as an intermittant wiper. I just said ohhh really that's neat. Got an entire new washer system and now I have washers again. Ohh and FYI if it gets below freezing the pump will stick till you get the heater going. Unless you use anti-freezin fluid. Ohh yeah, and it is a PITA to get the little hose that goes to the sprayers on and off the foot pump.
Old Jan 4, 2007 | 12:41 PM
crunchyskippy's Avatar
crunchyskippy
ORIGINAL: jrrhd73must
I can confirm that it is, in fact, a winshield washer pump. But I can also tell you with confidence that you are not alone in your initial assumption!
Welcome to the Confused Club. At least now you know!
Old Jan 4, 2007 | 02:45 PM
THUMPIN455's Avatar
THUMPIN455
Having a fondness for 67 Cougars, if she dont like it I would..lol. If I ever got the cash for it with all the projects underway..lol.
The park brake pull handle needs to be turned to get it back in, just so you know. Cougars are awesome first cars, I know I had way too much fun in mine (and now I am fixing all the fun I had with it) One thing to remember about them is there arent many reproducitons made for them, no fenders, doors or other sheetmetal is offered, that means you need to find a donor or buy one from someone who has parted it out. If you cant do either of those, its time to start fabricating.
Interior parts are difficult to find, the stuff that isnt Mustang or Cougar but Cougar only. Like door panels and dash parts. Trim is another place where things get ugly fast, nobody makes it like they do for Mustangs.
So tell her not to bend the car, and if the tail lights arent sequential, do the LED swap.. That is one of the coolest things about the Cougars, other than they arent like any other cars.
Old Jan 4, 2007 | 03:52 PM
jrrhd73must
The sequential part does not work on the tail lights. I am not sure if it was an option or just inop. I am really interested in the LED conversion!The sheetmetal is all good that is why I bought it. I may have some cowl repairs, I am not sure. The drivers floor pan is toast - will a mustang fit? The dash it self is good, needs new dash pad, and I want to redo the whole interior. The car is really straight for the little money I have in it. It is going to be a wiring nightmare since none of the idiot lights work. I am going to concentrate on the mechanical brakes, engine, trans for now.
As far as the flip up lights go, I am assuming there are aftermarket parts availbale to refurbish them?
Old Jan 4, 2007 | 08:07 PM
andrewmp6's Avatar
andrewmp6
thats the funniest thing i heard today lol a car that old id just rewire it all with a kit like painless the floor pan im not sure on the mustang one might fit
Old Jan 4, 2007 | 08:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
I wouldn't order a Mustang floor pan. Get your Cougar body panels and floor pans, etc. from places like this.
http://www.autopn.com/autoparts/body...dy_panels.html
allfyre
Apr 25, 2007 12:42 AM
Professor Wizard
Mar 25, 2006 12:17 AM
ghoste
Jul 3, 2005 12:30 AM
krafty02
Mar 10, 2005 07:09 PM
bobby
Mar 8, 2005 10:02 AM
