where do i ?
Old Jan 7, 2007 | 05:45 PM
LCC's Avatar
LCC
Default RE: where do i ?
they go inside the vale cover and block any oilthat isbeing thrownat the fill hole.
Old Jan 7, 2007 | 06:24 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
u buy a kit to put the fill hole where u want it my hs auto teacher had those on his boss 347 motor he built
Old Jan 7, 2007 | 06:42 PM
baddog671's Avatar
baddog671
ORIGINAL: Colorado_Mustang
They're baffles that go under the two holes to prevent oil from splashing out.
Or you could just keep the cap on when the car is running
Old Jan 7, 2007 | 11:15 PM
Aussie66Fastback's Avatar
Aussie66Fastback
ORIGINAL: the289
ok im now thinking of getting these but wht are those 2 plates for?
[IMG]local://upfiles/58143/8422207CF34A4F659D784149E8727BFC.jpg[/IMG]
with the Ford Racing ones, you have to get the holes cut in for oil and also need breather/ PCV valve. I bought mine second hand so it was all done. Apparently its not too hard to do and then you just get rubber gromets to fill the holes and plug your filler cap/ pcv/ breather straight in.
Ideally youd fit the same or longer baffles as the second set you posted. The baffles are supposed to stop oil from splashing into the breather/ pcv valve.
Have a look at a few pics...heaps of guys have them and they look great!
Old Jan 7, 2007 | 11:19 PM
4reboy's Avatar
4reboy
I'm sure if you look around you can find the ford racing valve covers that are already cut
Old Jan 7, 2007 | 11:52 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Here, try these!! http://store.summitracing.com/partde...p;autoview=sku
Old Jan 8, 2007 | 03:29 AM
BillyBobJoe's Avatar
BillyBobJoe
^^^Cheers, I was looking into those with Red lettering and black background, and then I decided on this pair from NPD.
Old Jan 8, 2007 | 04:22 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Oil will come through your breather and squirt oil directly into your PCV valve and ultimately your intake. All factory OHV engines have baffles in the valve covers, genius.
OHC engines don't need them due to how the top end is oiled.
ORIGINAL: baddog671
