factory hood hinge mount?
Old Jan 7, 2007 | 08:24 PM
green_blurr's Avatar
green_blurr
Default factory hood hinge mount?
Im just gonna take a guess but it looks like someone hacked away at these poor fender aprons?
[IMG]local://upfiles/43944/724E99C8C71644C2BFDFABCED2F873BC.jpg[/IMG]
Old Jan 7, 2007 | 09:13 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: factory hood hinge mount?
Yep, a hot torch will do that.
Old Jan 7, 2007 | 09:14 PM
green_blurr
should i replace these?
Old Jan 7, 2007 | 09:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
Are you asking about replacing the inner fender? If so, I don't know. Without a larger picture of the inner fender, it's hard to tell even though there is evidence of some rust. Here's mine. Will that inner fender hold the spring, or do you think the inner fender is too weak?
[IMG]local://upfiles/10034/A1D1DA2583C641A9854938856D57370D.jpg[/IMG]
Old Jan 7, 2007 | 09:45 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Weld a washer to a nut and then weld the washer to the apron. Much easier than repacing the entire apron. Use the hood hinge to hold everything in the correct position.
Old Jan 7, 2007 | 09:48 PM
green_blurr
how about this?
[IMG]local://upfiles/43944/6EB74DB07D5D4E3E80C1110B121DF999.jpg[/IMG]
Old Jan 7, 2007 | 09:51 PM
green_blurr
Thats what looks like was done it looks like crap too
Old Jan 7, 2007 | 09:54 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, it looks like you still have a good inner fender that will hold the hinge. Do like 67ponycoupe suggested, and for that hole that doesn't have a nut welded to it, just weld a washer to a nut then weld the washer on the opposite side of the hole. Using some correct size grade 8 bolts and nuts and lock washers, you should be good to go. It would be interesting to know why those bolts were cut off with a cutting torch. If only cars could speak.
Old Jan 7, 2007 | 10:00 PM
green_blurr
I still know where my previous owner lives, sometimes i think about coming after him at night hoping to catching him making something in the bathroom and holding him at gunpoint making him tell me what the hell he did to the car he sold me..
Old Jan 7, 2007 | 10:10 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: green_blurr
At first glance it looked like he wanted that hinge for another application, and cut it out. Now that you mention it, it does appear that the nuts were welded in. But, at any rate, how else would you repair it? You have to have a nut welded to the apron so you can bolt the hinge to the apron.
