Product Review
Old Jan 8, 2007 | 10:57 AM
jrrhd73must's Avatar
jrrhd73must
Default Product Review
Eastwood RustConverter and Rust Encasulator
I wire brushed some rusty floor boards, and then used the disolver, and then used the encapsulator. I am welding in some new parts of the floor pans, and I had to go strip off some of the Eastwood products so that I can weld to bare metal. I had a really tough time getting that stuff off of the floor pans. So I am really happy with the products. If I had that hard of time getting it off, then it is doing the job I wanted to protect the floor.
Old Jan 8, 2007 | 11:39 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Product Review
Yeah, from what I can tell, most rust encapsulators have the same chemical make-up. I used "Rust Away" that you can get at Ace hardware, and it turned the rust black and hard as a brick. I was going to order some POR 15, but didn't want to wait for it with my trunk torn down to the tank. Now, that was about a year ago that I did this. A few days ago, I have to take up the trunk mat to check on something, and the trunk is still black and hard as a brick, so I guess it has done its' thing.
Old Jan 8, 2007 | 12:07 PM
andrewmp6's Avatar
andrewmp6
i trust anything eastwood sells i have alot of there tool kits and the powder coating one
Old Jan 8, 2007 | 12:30 PM
stangimgood's Avatar
stangimgood
Soaring...is Rust Away a converter or encapsulator? i use eastwood because untill now we have not had an ace hardware close enough to drive to.......thanx
Old Jan 8, 2007 | 02:57 PM
67Stang68's Avatar
67Stang68
Rust encapsulator is a good product but I always found it to be too thin, I prefer Por 15.
Old Jan 8, 2007 | 06:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: stangimgood
I guess it's a converter since it chemically alters rust into a protective polymeric coating on iron and steel.
FivePointToTheOh
Mar 9, 2020 10:26 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
