my bell-housing
Old Jan 8, 2007 | 04:42 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default my bell-housing
so i am putting my engine in right now and i noticed that there is a crack in my bell housing on the dowel pin thing in the driver side of my c4 what i want to know is if it will be ok to drive around for about a month or so until i can afford to fix it
Old Jan 8, 2007 | 07:09 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: my bell-housing
Hard to say without pictures but if it is just for the dowel pin I would not worry about it. The pin is only to help align it on installation.
Old Jan 8, 2007 | 08:30 PM
THUMPIN455's Avatar
THUMPIN455
If its on the outside dont worry about it too much. If it is going into the bellhousing, get another one. I think I have a couple back home in Nebraska if you cant find one. the dowel pins also locate the trans behind the engine, without them the trans would move around under power and destroy the front pump, rear main bearing and possibly the thrust bearing..
Also aluminum can be welded quite easily.. If you are concerned about it take it to a machine shop and ask if you can have it Tig welded.. They will know what you mean..
Old Jan 9, 2007 | 02:14 AM
Brandontyler65
I ♥ Acer
its just on that one dowell pin abut all of the bolts are in place so it should be ok to drive normally for a month or so right just cause i have no money to do it
iateadonut
Dec 4, 2014 12:53 PM
LaMotta
Aug 21, 2013 02:25 PM
tbone5448
Mar 30, 2012 10:37 AM
g3mustang
Jun 27, 2011 11:26 PM
6mustang6
May 29, 2006 05:43 AM
