T5 conversion question
Old Jan 10, 2007 | 11:37 PM
joe68stang's Avatar
joe68stang
Default T5 conversion question
Getting ready to do a T5 swap on my 68, 289 three speed stick. I am using the late model bell housing. one thing is not clear to me. do you need to change the block plate out to a late model? or can you use the 68 style? If using the late model style, do you need to change the starter to a late model? if so, will the late model require a different flywheel? I had read that you can use the original flywheel.I also read somewhere you could use a early model starter for a auto trans. Thanks for the help. Joe
Old Jan 10, 2007 | 11:42 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: T5 conversion question
Block plate, starter and flywheel should be ok. Since you are using the late model bellhousing, you are planning on changing to a cable clutch instead of the Z bar then I assume.
Old Jan 10, 2007 | 11:48 PM
joe68stang's Avatar
joe68stang
no, I am using the original style clutch linkage. I purchased a flacrom block. I like the feel of the original pedal.
Old Jan 10, 2007 | 11:52 PM
67t5ponycoupe
The late model bell housings use a pull type fork vice a push type like on the early cars. The fulcrum is in a differnt place. It pivots on the far side of the bell housing vice the near side. Have you taken this into account? It will make a big difference.
Old Jan 10, 2007 | 11:54 PM
67t5ponycoupe
Dooh! I just read your post again. I guess you have planned for that. Good job. I went the other way with mine and used and early bell housing with an adapter plate.
Old Jan 10, 2007 | 11:59 PM
joe68stang's Avatar
joe68stang
Thanks for the input.
Old Jan 11, 2007 | 12:27 AM
andrewmp6's Avatar
andrewmp6
you got the crossmember and all the parts to do it
Old Jan 11, 2007 | 09:08 AM
joe68stang's Avatar
joe68stang
Yes, I have all the other parts including new clutch and throwout bearing. Thanks
Old Jan 11, 2007 | 09:12 AM
JamesW's Avatar
JamesW
Never heard of it being done quite this way.
You're running an early model flywheel/clutch/pressure plate setup inside the late model flywheel?
'dust shield between the block and flywheel should be ok. Only question I'd have is does the old starter still work.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
