Intake manifolds
Old Jan 14, 2007 | 12:24 AM
thepepsifiend's Avatar
thepepsifiend
Default Intake manifolds
Ok so here it is. Everywhere I look around the forum it seems like there are 3 top intake manifolds. I will shortly be putting together a 351W to drop into my mustang. The engine will have AFR 185cc heads, a comp cams roller cam, and the carb will most likely be demon carb or another card around 650 cfm, at least thats what I'm thinking. I might want to go 750 cfm but thats another post for another time. I am looking at 3 different manifolds.
the 3 intakes I am looking at:
Edelbrock Performer RPM- 1500-6500 rpm pretty solid basic intake
Edelbrock Performer RPM Airgap- 1500-6500 RPM but gap delivers cooler air (in theory)
Weiand Stealth- idle-6000 rpm better low end power might be quicker off the line?
Which one do you think is the best. Does the Airgap design really work? Is the Weiand the best best due to the better rpm range? What do you think?
Old Jan 14, 2007 | 12:30 AM
Yonco's Avatar
Yonco
Default RE: Intake manifolds
i have a stealth with a 600 holley and have no complaints! -Jon
Old Jan 14, 2007 | 12:46 AM
mustanglover66's Avatar
mustanglover66
I plan on going with a webber setup much better throttle responce and torque than single carbs and EFI
Old Jan 14, 2007 | 01:23 AM
eZ's Avatar
eZ
how do webbers run thier air cleaner?
Old Jan 14, 2007 | 04:21 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
the weiand is the same casting as the aluminum shelby manifold from back in the day cause guess who made those manifolds for shelby it was no one other than weiand
Old Jan 14, 2007 | 04:25 AM
atomsk680's Avatar
atomsk680
go weiand
Old Jan 14, 2007 | 06:25 AM
scott_m_mil's Avatar
scott_m_mil
If the weiand its ranked at idle - 6500 theoretically yes you would make lower power for better take off. But, where do you launch at that would be the bigger question there. Between the two Edelbrocks I would definately take the Air-Gap model. It does help. Unfortunately I have no experience with Weiand intakes.
Old Jan 14, 2007 | 11:05 AM
Soaring's Avatar
Soaring
I ♥ Acer
Weiand Stealth. None better for classic Mustang engines.
Old Jan 14, 2007 | 11:41 AM
my77stang's Avatar
my77stang
no experience with the weiands dual planes but i do like the airgaps... i always keep in mind that 1500 is not that far away from idle anyways ya know?
we used some of the weiand single planes on a run of hopped up sbc airboart motors and the customer was very please with them, but thats a whole different usage.
Old Jan 14, 2007 | 11:43 AM
mustanglover66
ORIGINAL: eZ
this pic shows them they the little black thing on top of the stacks
[IMG]local://upfiles/33399/DCBB2BF6DCFB4289AE09E4A73508013E.jpg[/IMG]
