Passenger Quarter Panel = Devastated
Old Jan 17, 2007 | 12:08 AM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: Passenger Quarter Panel = Devastated
yeah its solid but i mean its as if you were feeling a bag of golf *****........still just fill it all and be done with it?
Old Jan 17, 2007 | 12:18 AM
dodgestang's Avatar
dodgestang
I still don't see anything that needs to be replaced....smooth it out as much you can with metal work and then thin fill for finish prep. If you want to cut it out and weld in a new piece you'll prob use just as much filler over the new seam to get it the way you want.
Old Jan 17, 2007 | 10:11 AM
supermanzx9r's Avatar
supermanzx9r
when welding in the rear of the car like the quater panel should we drain the tank or take it out completely , i can allways smell gas even when my gas cap is on (only when i am in the trunk area)
Old Jan 17, 2007 | 11:18 AM
Grimm's Avatar
Grimm
Hey Shifty. It looks like you have some bondo on the rear lip of the wheel opening as well. Is that the case? My entire lip is about an inch of bondo. Make sure you sand down all the paint before you buy a panel. I thought the same thing about just the patch until I kept sanding and found that there was bondo everywhere.
[IMG]local://upfiles/52170/79DB9C3214054CD5A16AE9143B97605D.jpg[/IMG]
[IMG]local://upfiles/52170/92AFEEADB4D94693AB3F4444A877EE6E.jpg[/IMG]
Old Jan 17, 2007 | 11:45 AM
THUMPIN455's Avatar
THUMPIN455
What you have there is a shoddy 70s to 80s collision shop quickie fix. Bondo was the new thing and they figured it would last forever, and that they could just sand it to shape rather than fixing the dent. Work the high spots into the low spots, that is dont just pound out the lowest part of the dent first, work around the edges and try to get the part that is pushed in out a little at a time. A high spot is where the wave of the dent protrudes above where the fender should be, a low spot is where its farther in than it should be. You will need to pull the interior panels and the rear window regulator to work that dent.
Also read up on metal shrinking with heat, because dents stretch the metal often you need to shrink it so it isnt a bubble once its pushed out. its called metal bumping, not metal bashing for a reason, the more you work it, the more you stretch it. Kinda like playdough being rolled flat, it gets bigger the thinner you make it, right?
If you have a decent mig, filling the holes in will give you the opportunity to do some shrinking and fix the stupid dent puller holes. Have the same issues on the Cougar and nobody makes replacement panels, so we just gotta fix what we have. Mustangs are quite nice in that repsect, you can get almost anything for them.
You want a skim of filler, not 1"-4" of filler like it had. At most a 1/4" if you absolutely need to fill something in. I use a 2"x3" board that is about 4' long to see how the doors and fenders/quarter panels line up. You want it to be the same level all the way across rather than a dip where the door meets the quarter. Behind the scoop you just need to get it as smooth as possible and close to the other side.
About the rust, look on the inside of the fender lip after you have pulled the panel and regulator. If its flaky and rusting up in there, you may as well replace the panel because it will come through in a matter of time. That will allow you to get in there, clean it up and prep it so it wonr rust again.
jut some ideas..
Old Jan 18, 2007 | 06:34 AM
Shifty101Easy
ORIGINAL: THUMPIN455
jut some ideas..
wow thanks for the lengthy write up and effort to help! i have been thinking for a long time of side scoops to go along with the whole "California Special" look im going for without actually having it be a complete GT/CS clone...i was gonna leave off the side scoops but after finding this damage i figured id could cover some of it with regular GT/CS side scoops...then i was looking on ebay and saw "Eleanor Style" side scoops and started thinking....they are usually molded into the quarter panel with fiberglass matting right? i could just do that over some of the damage and the fix the rest that is exposed...? i think it would help the overall appearance of "straightness" on that area of the panel, plus would look totally sweet....what do you guys think?
Old Jan 18, 2007 | 06:35 AM
Shifty101Easy
http://cgi.ebay.com/ebaymotors/67-68...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true - cheaper too!
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
Sixer4Life
Sep 29, 2015 07:03 PM
