2v 3v 4v
Old Jan 17, 2007 | 09:30 PM
andrewmp6's Avatar
andrewmp6
Default 2v 3v 4v
what do they all mean and which is better
Old Jan 17, 2007 | 09:32 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: 2v 3v 4v
well that depends on what you are talking about carbs are usually 1v,2v,4v where as most cyl heads are either 2v,3v,4v so you gotta be more specific
Old Jan 17, 2007 | 09:58 PM
ZZmustang's Avatar
ZZmustang
Banned
In old engine specs the V meant Venture, a 4V was a 4barrel carb
On new engine specs the V means Valve 4V means 4 valves per cylinder
By the way a 3V was a 950 Holley 3 barrel., back barrel was a Twinkie looking venture.
Old Jan 17, 2007 | 10:06 PM
Rorin67's Avatar
Rorin67
ORIGINAL: ZZmustang
Um... you mean "venturi" right?
Old Jan 17, 2007 | 10:39 PM
ZZmustang's Avatar
ZZmustang
Banned
I mean venturi right and left.
Spell check don't talk engines
Hope I didn't get any points off for spelling
Old Jan 17, 2007 | 11:23 PM
longlive289s's Avatar
longlive289s
ya as above all stated.
carbs: 2v is two barrels that lead into the intake, ive never heard of a 3v carb but 4 is two primary barrel's and 2 secondaries. the more barrel's in theory the more power (gas and air) that can be put into the cylinders thus bumping up the compression ratings.
valves: 2 valve is one valve for intake and one for exhaust. 3v are used in the brand new stangs. im not totally sure what the set up on them is. and 4v of course is 2 for each intake and exhaust. again more valves gives u better compression and more power.
note that of course the more valves or barrels (sorry....venturi's) the higher the price for the product....usually
Old Jan 18, 2007 | 12:24 AM
andrewmp6's Avatar
andrewmp6
im talking about the heads on the older engines not the newer ones take a look http://www.chiheads.com/cylinder_heads_ford.php
Old Jan 18, 2007 | 12:53 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the 2v are 2 barrel heads4v 4 barrel and the 3v are hybrid heads little of the 2v with a little of the 4v just 3v to simplify it
Old Jan 18, 2007 | 03:18 AM
scott_m_mil's Avatar
scott_m_mil
My dad's first carb on his '67 fastback was a holley 3 barrel. I've never seen one or heard of one other than from him.
Old Jan 18, 2007 | 03:22 AM
scott_m_mil
Okay,
Did some research. Holley 3bbls came in more than jsut the 950cfm. And I'm sure that cfm ratings are somewhat differnt for 3bbl vs. 4bbl just like they are for 2bbl vs. 4bbl. Here are some pics:
http://www.marketworks.com/StoreFron...&i=9738709
