timing on 302
Old Oct 4, 2004 | 12:51 PM
kevs66coupe's Avatar
kevs66coupe
Default timing on 302
i have a 66 stang with a 302 that i just put in it and i was putting the spark plug wires in and i was wondering..i turned the engine over until the number 1 piston was at top dead center but i don't know if it was on the compression stroke or the power stroke? does it have to be on the power stroke to make sure that im installing the plug wire right or does it even matter? aslo ...my dipstick tube is hitting the alternator so i turned it so it wouldn't hit it ...i haven't started the engine up yet but does it matter what direction the dipstick goes in? thanks for all replies
Old Nov 3, 2004 | 07:27 PM
69mach1377's Avatar
69mach1377
Default RE: timing on 302
Yes on the power stroke.
No on the dipstick.
Old Nov 3, 2004 | 07:29 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
the compression stroke is the power stroke, and yes when it blows out thats the compression stroke
Old Nov 3, 2004 | 09:12 PM
carizzma's Avatar
carizzma
Put your finger on the spark plug hole when turning the engine over the compression stroke will force your finger off. When the pistin is coming up on the exhaust stoke the exhaust valve will be open & no compression pressure.
Old Nov 4, 2004 | 04:55 AM
Soaring's Avatar
Soaring
I ♥ Acer
You can also use a pencil or a screw driver to feel when #1 piston is at the top. And, be sure you have the right firing order. For a standard 302 it is 15426378 but for HO302 it is 13726548.
carid
Jul 8, 2016 09:55 AM
mungodrums
Oct 7, 2015 04:01 AM
StalkerGT
Sep 25, 2015 02:41 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
