Holley Carburetor
Old Jan 20, 2007 | 09:56 PM
rlbjrcpa's Avatar
rlbjrcpa
Default Holley Carburetor
After pulling my carb, I was able to see that it is a Holley, list #R-2143. After some research, using the part # CC2AE-9510D that's on the carb, looks like it is a 4160 that was originally on 1960-1962 Ford and Mercurys with a 390 engine. Is this too much carb for my 289? Is there any chance this is the original for my car? I have heard that Ford used to use old parts sometimes from past production runs.
Also, anyone know if this is a rare list and part #? I could not find any info on the Holley site for list # 2143.
Thanks
Old Jan 20, 2007 | 10:00 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: Holley Carburetor
any chance you can post a pic of it? Does it have one fuel inlet and a transfer tube going down the drivers side between the floats? Or does it have two fuel inlets? If it has two inlets, are there two metering blocks on it, one for each bowl, or is there just one block on it?
Old Jan 20, 2007 | 11:43 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Sorry, but there is no way it's original. And it probably is big, unless your 289 is a screamer. How's it run?
If the carb is off you can determine the size by turning it over and reading the numbers on the trottle plates.
TP# CFM
107/116 550
109/118 600
172 715, 735, 750, 780.
180 800
Full size '61-'62 looks to be correct. Remember, Holleys were only used for the hipo motors. Big or small block.
Having the ford number gives it value. There should be a third line on the airhorn with a three digit date code. Y/M/W.
Maybe you could get enough for it to buy the one you want. (C5ZF-C, C5ZF-E)
Do some research and good luck.
1966 Mustang GT Fastback,
289 4v 4speed,
Ivy Green over black.
Old Jan 21, 2007 | 12:04 AM
my77stang's Avatar
my77stang
600 cfm (which is what it prolly is) really isnt too much for a 289 - specially if your doing anything at all to pep that 289 up.
Old Jan 21, 2007 | 12:14 AM
rlbjrcpa's Avatar
rlbjrcpa
I'll take some pics tomorrow and post them. thanks.
Old Jan 21, 2007 | 12:24 AM
rlbjrcpa's Avatar
rlbjrcpa
Also, I checked the numbers on the plates- 107/116.
Sounds like I have a 550cfm.
Old Jan 21, 2007 | 01:07 AM
THUMPIN455's Avatar
THUMPIN455
kinda what I was thinkin too.. 550-600 cfm. get me a good side view and a top view if possible.. and all the numbers from the choke horn..
Old Jan 21, 2007 | 10:49 AM
Jsprint68's Avatar
Jsprint68
Three years is an offal long time for a part to be sitting at an assembly plant.
Old Jan 21, 2007 | 03:05 PM
rlbjrcpa's Avatar
rlbjrcpa
Here are some pictures of the carb.
[IMG]local://upfiles/54380/E05638B4C4A34427A56C9A02FB1BDAD8.jpg[/IMG]
[IMG]local://upfiles/54380/413303E5D01D4692A0691F915E1EA842.jpg[/IMG]
Old Jan 21, 2007 | 03:06 PM
rlbjrcpa's Avatar
rlbjrcpa
Here are a couple more with a different view.
