Cams
Old Jan 22, 2007 | 01:21 AM
fast65's Avatar
fast65
Default Cams
My lifters are bad on my 302 so I decided to get a new cam while I'm at it to save me time later. My question is what kind of cam should I get (duration, lift, brand)? I want to get a good increase in horsepower, but not enough to **** off my parents (I could careless if I **** off the cops). So what should I do?
Old Jan 22, 2007 | 03:13 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: Cams
What kind of heads do you have? Intake? Exhaust?
For a stock engine, this kit from Summit would be what you'd want. If you aren't stock, let us know what you have.
Old Jan 22, 2007 | 04:13 AM
ZZmustang's Avatar
ZZmustang
Banned
Default RE: Cams
Old Jan 22, 2007 | 03:16 PM
my77stang's Avatar
my77stang
Default RE: Cams
colorado, summit wants 358 for that kit.... WTF are they thinking?
check this out, i had one in a stock springed 302 and it was great off the line!
http://store.summitracing.com/partde...p;autoview=sku
80 bucks and even though the power range says 2000-4500 thats wrong cause with a factory ford dual plane intake (aluminum from a 83 GT), a holley 4160 600, and exhaust manifolds and single exhaust the car idled great and had crazy power off the line. and it pulled strong up to 5000-5500
Old Jan 22, 2007 | 05:59 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: Cams
thats the kit i am thinkin bout gettin cause its not a racecar its just a DD
Old Jan 22, 2007 | 06:36 PM
symbiote's Avatar
symbiote
Default RE: Cams
does the car sound gruntier than before?
Old Jan 23, 2007 | 12:24 AM
Colorado_Mustang
Default RE: Cams
That kit includes the timing set, lifters, springs, locks, retainers,and the cam. Anytime you change a cam in an engine with some age, you'll want to replace the timing set. Springs are in the same boat. While you can run a performance (even mild) on stock springs, they will wear out quicker and you will lose you top end quickly due to valve float.It's a little more work, but you will definitely have the best quality with that kind of kit.
ORIGINAL: my77stang
Old Jan 23, 2007 | 02:26 AM
restomod66's Avatar
restomod66
Default RE: Cams
What do you guys think about Competition cams or Crane cams??
Old Jan 23, 2007 | 02:29 AM
atomsk680's Avatar
atomsk680
Default RE: Cams
ORIGINAL: restomod66
very very good cams and kit
Old Jan 23, 2007 | 03:03 AM
THUMPIN455's Avatar
THUMPIN455
Default RE: Cams
Have run both Comp and Crane. Both make quality products. The cam kit that Colorado posted would be perfect for a stock 289/302 with stock manifolds. Replacing the springs, locks, retainers, timing chain, along with the cam and lifters is good advice. You are in there, why not do it?
Even my daily drivers get new springs, control of the valve is more important than most people realize.
If you are on a budget, then at least do the timing chain with the cam and lifters.
