carb trouble
Old Jan 22, 2007 | 04:46 AM
bombone's Avatar
bombone
Default carb trouble
i have an edlebrock 1407 in my 66. i was pulling out of a friends driveway the other day and my car stalled, couldnt get it started. pulled over and my carb was leaking fuel on the side that the throttle is not on. i tried to start a couple of time all the fuel that was is the filter would drain into carb and then i guess in to the engine.. i did realize that i needed to stop trying to start the car with the fuel leak but could someone tell me what happend.... my buddy said i need a holley carb and that will fix my problem.
Old Jan 22, 2007 | 06:39 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: carb trouble
Sounds like your float got out of whack and is allowing too much fuel into the bowl. Overhaul the carb. The needle and seat are probably worn out.
Old Jan 23, 2007 | 12:59 AM
Colorado_Mustang's Avatar
Colorado_Mustang
+1
Although I'm no fan of Edel carbs, they do work. Check the needle/seat and float as Glen mentioned. It is possible the float lost its bouyancy.
Old Jan 28, 2007 | 03:00 PM
bombone's Avatar
bombone
thanks guys
Old Jan 28, 2007 | 03:07 PM
shr's Avatar
shr
sound like a problem that i had on one and it was the needle seats and float, so i agree with everyone else on this
Old Jan 28, 2007 | 03:08 PM
6mustang6's Avatar
6mustang6
i like Edelbrocks. I have more trouble out of holley.s
Old Jan 28, 2007 | 03:25 PM
bombone's Avatar
bombone
i have a new post called having problems that tells you where im at now...and im still having problems
Old Jan 29, 2007 | 04:27 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
i say check float/ needle and seat and second both are good carbs you just gotta get used to it and know the systems
Old Jan 29, 2007 | 02:34 PM
Bulldog66's Avatar
Bulldog66
I just like to rebuild things. Carbs are on top of my *like* list of things to rebuild.
It's not that difficult. Just get a clean working surface, a good rubber tip air nozzle and a place where you can clean parts. You know it's done right and you'll know where to look should it act up.
Just tear it down and put it back together. It's about a 2 hour job if you've never done it before.
Good luck.
CS2007
Jun 25, 2019 09:45 PM
bradleyb
Nov 27, 2015 07:50 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
