Carb. spacer
Old Jan 22, 2007 | 03:39 PM
dozierstang's Avatar
dozierstang
Default Carb. spacer
Hey,
I have a 1/4" spacer on my carb right now that is shot. It is one of those fiber ones and it is just too old. Anyways, I was thinking about getting a 1" aluminum spacer for the carb. Has anyone done this? I heard it is supposed to bump up the torque a bit but the engine I have already kicks. They are not that expensive but I am also going with a 3" filter and wonder if I will have enough hood clearance. What do you think?
Old Jan 22, 2007 | 03:47 PM
grruminator78's Avatar
grruminator78
Default RE: Carb. spacer
well for the filter part, just get a drop base (I'm guessing it's a K&N) oh and for those filters and drop bases and tops, the best price I found was on amazon.
Old Jan 22, 2007 | 04:54 PM
Soaring's Avatar
Soaring
I ♥ Acer
I would recommend a phenolic spacer over an aluminum one. The aluminum will give you some heat transfer from the intake to the bottom of the carb, where the phenolic won't.
Old Jan 22, 2007 | 06:55 PM
groho's Avatar
groho
all the major car magazines have done dyno's on carb spacers, and the 1" spacer has historicallyprovided to most hp/torque, I believe it's related to increased velocity. The OEM spacer is aprox $40-50 at a boneyard, they're not cheap(obviously CA prices).
Old Jan 23, 2007 | 12:26 AM
Colorado_Mustang's Avatar
Colorado_Mustang
I run a 1" spacer on my 390 HiPo and it definitely makes a difference in throttle response.
Old Jan 23, 2007 | 11:08 AM
my77stang's Avatar
my77stang
soaring..... so two pieces of 1/2 plywood and he'll be set eh?
Old Jan 23, 2007 | 11:14 AM
Soaring's Avatar
Soaring
I ♥ Acer
Don't laugh, It was done on race cars for many years.
Old Jan 23, 2007 | 12:22 PM
my77stang's Avatar
my77stang
anytime plywood and engines come together, its bound to be funny though
Old Jan 23, 2007 | 01:56 PM
eZ's Avatar
eZ
phenolic? WTF?
Old Jan 23, 2007 | 02:44 PM
gothand's Avatar
gothand
Don't laugh, they sell wood spacers. FWIW, a 1" spacer is not going to work on my '65 with a 302 and an Edelbrock RPM air-gap manifold and a reproduction hi-po air cleaner.
