Horse Power
Old Jan 24, 2007 | 04:05 PM
ZZmustang's Avatar
ZZmustang
Banned
Default Horse Power
What do you think is the MOST horse power ever produced by an engine assembly.
An engine assembly is one or more engines hooked together to form One unit.
Old Jan 24, 2007 | 04:06 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: Horse Power
well whatever it is you won't be able to fit it under your hood
Old Jan 24, 2007 | 04:24 PM
Lumbergh's Avatar
Lumbergh
What kind of engine? I've seen gas fired turbine engines that produce 17 megawatts(MW) which is about 23,000 hp. I've seen back up diesel generators that produce a more modest 2 MW, 2,700 hp. I'm not sure how much horsepower a deisel engine on a train produces, but its probably in the 2,000 to 3,000 hp range.
Went ahead and looked it up. The most powerful engine produces over 100,000 hp. You can find out more here: http://www.k4viz.com/12-Cylinder.html
Old Jan 24, 2007 | 05:03 PM
my77stang's Avatar
my77stang
hahahah 100,000 HP at 101.5 RPM's
crank that sucker up to 7k!!!!!!!!!!!!!
btw, i have one of these on my kids go-kart
Old Jan 24, 2007 | 05:22 PM
scott_m_mil's Avatar
scott_m_mil
What about a rocket engine. THe Apollo Rockets put out 160,000,000 horsepower
Old Jan 24, 2007 | 05:58 PM
grruminator78's Avatar
grruminator78
how about top fuel dragsters?? http://www.nhra.com/streetlegal/funfacts.html
Old Jan 24, 2007 | 06:15 PM
ZZmustang's Avatar
ZZmustang
Banned
Scott
You win the bronz monkey
160 million Horse power. 7.5 million Lbs of thrust. 21.333 Horse power per Lb of thrust.
The most powerful engine assembly ever made
Saturn 5 rocket had 5, 1.5 million LB. of thrust engines that powered the apolo missions.
350 feet long. One is laying on it's side at Johnson space center in Houston, The exhaust pipes are about 9 feet in Dia.
One of these engines would fit in a 8X10 room and if bolted to a dragster would make around 200 Gs of force. You would be a stain on the back seat of the dragster. 1/4 mile in .003 seconds, after ignition.
No tires required.
[IMG]local://upfiles/58274/3297778F99B241E89F31DE68848C578C.jpg[/IMG]
Old Jan 24, 2007 | 06:17 PM
scott_m_mil
HAHA Being a nerd does have its advantages ! And I have seen that sucker she be big!!!
Old Jan 24, 2007 | 06:19 PM
scott_m_mil
You think that baby's gotta 4 speed?
THUMPIN455's Avatar
THUMPIN455
Okay what engine runs on Diesel, is started with a small rope, has a stroke of about two feet, a bore of 2 feet, no connecting rods, no crankshaft, no exhaust valves, and only three moving parts other than the single injector?
