New Coil
Old Jan 25, 2007 | 07:42 PM
symbiote's Avatar
symbiote
Default New Coil
I was thinking of upgrading my ignition coil...attached pic.....any ideas? is replacing this a simple matter of taking the old one out and replacing it with a new one or does one need to change the attaching wire as well( for the red and blue terminals)?
http://img143.imageshack.us/img143/834/dsc005998bv.jpg
Old Jan 25, 2007 | 07:49 PM
65mojoe's Avatar
65mojoe
Default RE: New Coil
Pertronix flamethrower ftw, and no, you don't have to change the wires.
Old Jan 25, 2007 | 07:51 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
ya get one to go with your pertronix module
Old Jan 25, 2007 | 08:06 PM
symbiote's Avatar
symbiote
that sounds good.....will anything work tho? someone mentioned a company MSD or something...MSD Flamethrower..is that similar?
Old Jan 25, 2007 | 08:11 PM
65mojoe's Avatar
65mojoe
MSD is a Company that manufactures the popular 6A and 6AL electronic ign. boxes. Flamethrower is a brand name under the company Pertronix.
Two seperate companies.
If you want to upgrade your ignition the easiest route to go is this: http://www.mustangsplus.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=MPFMP&P roduct_Code=08590&Category_Code=ignition_moder n_kit
Old Jan 25, 2007 | 08:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
Actually, you don't need the kit at all. Just buy the module for like 65.00 and hook it up to your existing coil. The directions of how to hook it up come with the module. What's that Geico commercial??? Even a caveman can do it.
Old Jan 25, 2007 | 10:35 PM
67Sally's Avatar
67Sally
You should get a resistor and new wires. I'd also recommend moving the coil from the block to somewhere else. If you do want to put the coil in the same spot then don't bother with a new bracket because the new one won't let you put it in the stock position.
Old Jan 25, 2007 | 10:43 PM
bw71mach1's Avatar
bw71mach1
I just placed my order for the Pertronix II and Flamethrower II coil. I hope that it is all everybody says it is. Time will tell.
Old Jan 25, 2007 | 10:44 PM
Soaring's Avatar
Soaring
I ♥ Acer
No, he doesn't need to move anything. The location of the current coil is perfect. What weed did you you buy at a discount?
Old Jan 25, 2007 | 10:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: bw71mach1
You will love it.
