How to paint Chrome
Old Jan 27, 2007 | 07:35 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: How to paint Chrome
Thanks bro, there is were I am going;
THUMPIN455's Avatar
THUMPIN455
ORIGINAL: rmodel65
just scuff with some 320 it up spray it with the etch primer or wash it down with the ospho prime, then topcoat
Rmodel gets my vote.. This will work, be sure to degrease it before you spray anything on it. Removing chrome with acid would take a LONG time and it would also thin the metal. You also dont want deep scratches in it that you have to fill with primer.
Glen would it really bother you that much to have some chrome under the hood? Its not a big deal and nobody will call the factory correct cops on you..
Old Jan 27, 2007 | 08:16 PM
ADRIAN1's Avatar
ADRIAN1
ORIGINAL: THUMPIN455
ORIGINAL: rmodel65
[sm=funnypostabove.gif][sm=funnypostabove.gif][sm=laughat.gif]
Old Jan 28, 2007 | 02:55 AM
Lumbergh's Avatar
Lumbergh
I used KleanStrip Bulldog Black Adhesion Promoter to paint some chrome a couple of months ago. It says that it will stick to all automotive surfaces, and it worked great on the chrome. If you want it to be a flat black just leave it as is, otherwise use it as a primer followed by whatever paint you like. The only prep I did was to scuff up the chrome a bit with a scotchbrite pad and make sure it was clean. I got the stuff at a local paint store, but I imagine they have a website as well if you can't find it at a local paint store. I don't think that you will find it at a Lowes, Home Depot, etc.though.
Old Jan 28, 2007 | 04:30 AM
Shifty101Easy's Avatar
Shifty101Easy
yeah, it could actually even look good....
Old Jan 28, 2007 | 05:43 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
you could try this here in the smoke color i think that might look cool it will just look like it has been anodized
Old Jan 28, 2007 | 08:11 AM
Shifty101Easy
ORIGINAL: Brandontyler65
do you guys think that could work for my vent window frames?????????? the chrome is sorta peeling and i dont really wanna buy new ones that wont fit good or be able to buy the new repro like 5 times over by getting them re-chromed....they are good phsyically its just the idiot owner before me over sprayed them with primer and stuff....id like to just scuff and/or spot blast then spray with the chrome stuff there.....actually...come to think of it....all my chrome has overspray on it.....some windows two...... [:@]
Old Jan 28, 2007 | 08:13 AM
Shifty101Easy
ORIGINAL: Shifty101Easy
http://www.duplicolor.com/products/gold-chrome.html
Old Jan 28, 2007 | 10:31 AM
67 evil eleanor's Avatar
67 evil eleanor
Scuffing is the key! Scuff,clean with some type of acid based metel prep, 2k, let dry, wet sand,then paint. Works for me.
Old Jan 28, 2007 | 11:07 AM
kalli's Avatar
kalli
ORIGINAL: 67 evil eleanor
... clean with some type of acid based metel prep...
Brake cleaner spray will do for that matter.
kalli
