How do i adjust timing on 302
Old Jan 28, 2007 | 06:11 AM
papi_chulo's Avatar
papi_chulo
Default How do i adjust timing on 302
i need help
Old Jan 28, 2007 | 10:53 AM
bdwjdw's Avatar
bdwjdw
Default RE: How do i adjust timing on 302
turn the distributor
Old Jan 28, 2007 | 11:26 AM
Hornblower's Avatar
Hornblower
I ♥ Acer
Get a timing light, a piece of white chalk or whiteout, and a distributor wrench. Hook up the timing light to #1 cylinder. Mark the timing mark on the balancer at the 3rd mark with the chalk, and mark the tip of the pointer that is on the bottom of the timing cover. Loosen the distributor bolt. Start the engine. Point the timing gun to the white mark and pull the trigger. You will then turn the distributor until the pointer and the white line line up with each other. Kill the engine and tighten down the distributor bolt.
Old Jan 28, 2007 | 11:40 AM
baxsom's Avatar
baxsom
you need to unhook the vacuum advance as well
Old Jan 28, 2007 | 12:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: baxsom
Yes, thank you. Just unhook the vacuum line from the distributor and plug it with a screw.
Old Jan 28, 2007 | 07:26 PM
papi_chulo's Avatar
papi_chulo
thanks for the advice. Im going to give it a try, thanks again
Old Jan 28, 2007 | 07:35 PM
Soaring's Avatar
Soaring
I ♥ Acer
Hey Papi.....after you get it timed, get a pertronix electronic module and replace your points andcondenserwith that. You will be amazed at the difference in performance. They only cost about 65 bux.
carid
Jul 8, 2016 09:55 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Luke9222
Sep 4, 2015 06:46 AM
Sep 1, 2015 08:16 PM
