dang it
Old Jan 28, 2007 | 09:38 PM
baxsom's Avatar
baxsom
Default dang it
so i finally got my car running
got a new holley 4bbl
it started right up
timing is set at 6 degrees
test rides went very well
probably needs a little air fuel adjusting but overall a definite improvement
but today
just now
right in front of me
the car started idling poorly
and i started smelling gas
i take off the air cleaner and the front of the carb is leaking right by the acellerator pump
i feel around and the entire seal on the front bowl is leaking
i pull the front bowl off and the gasket looks like it was put on pinched
i am assuming that a simple gasket kit will fix this
it is a 4160C carb that comes with preadjusted floats
and doesnt have the screw on top or the sight window to adjust float level
so i doubt that the floats were set too high
dang dang dang
Old Jan 28, 2007 | 09:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: dang it
Why a holley? Why did you dedide to buy a holley and not a Motorcraft?
Old Jan 28, 2007 | 10:54 PM
baxsom's Avatar
baxsom
Default RE: dang it
because i didnt want to wait for one to be shipped
and because every single what carb thread on here all goes the same way
should have got an edlebrock
should have got a holley
demon is the way to go
nope go with autolite
i like carter
so since each brand had about as many positive as negative posts
i bought the one that was available immediatly
Old Jan 28, 2007 | 11:18 PM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: dang it
ORIGINAL: baxsom
i like carter
he's got a point....everyone dissagrees with everyone....
Old Jan 28, 2007 | 11:48 PM
baxsom's Avatar
baxsom
Default RE: dang it
just got back from autozone with a gasket kit
10 minutes
left carb on car
drained fuel via hose through vent hole
new gaskets on
restart
no leaks
we will see tomorrow when it cools back down
its no wonder shops charge so much for labor
Old Jan 29, 2007 | 01:03 AM
6mustang6's Avatar
6mustang6
Default RE: dang it
Holleys suck, you should have went Edelbrock.
Old Jan 29, 2007 | 01:28 AM
colostang's Avatar
colostang
Default RE: dang it
[:@] Demon is the way to go
Old Jan 29, 2007 | 01:31 AM
plainsmen's Avatar
plainsmen
Default RE: dang it
ORIGINAL: Shifty101Easy
ORIGINAL: baxsom
i like carter
That's BS!! No we don't!
Old Jan 29, 2007 | 01:37 AM
Gun Jam's Avatar
Gun Jam
Default RE: dang it
The Carter AFB Competition series FTW
Gun
Old Jan 29, 2007 | 02:46 AM
Shifty101Easy
Default RE: dang it
haha thats like 3-4 differnt carbs in the last few posts.....
