Fuel Sending Unit Replacement
Old Jan 28, 2007 | 10:24 PM
edawg17's Avatar
edawg17
Default Fuel Sending Unit Replacement
I will be replacing my gas tank soon and I was wondering, would it be a good idea to replace fuel sending unit rather than transfer the old one from the old tank? The old one was working when i drained and removed the gas tank. I have a feeling that it is something that does go bad and should be replaced now so that I don't have to drain the new tank in the future. What do you guys think?
Old Jan 28, 2007 | 10:45 PM
baddog671's Avatar
baddog671
Default RE: Fuel Sending Unit Replacement
YES! Replace the sending unit. They are cheap anyways so you might aswell repalce it now. Wait till you pull it out, it will probably be so nasty you wont think twice of putting it in the new tank.
Just make sure you get a new gasket ring for it and a lock ring. You can use your old lock ring too...
Old Jan 28, 2007 | 10:50 PM
Cogtx's Avatar
Cogtx
I'll have to vote on replacing it while you have the new tank. If it's the original sending unit, chances are 40 years+ may be wearing the little filter sock on the end of the unit and eventually get pin holes in the float. I know mine was that way and I have replaced the tank and sending unit. Tip: use a hard wood block to tap/loosen the metal retainer off of the unit. Metal to metal = sparks = fire = boom,boom. No one likes boom-boom being that close to the source..
Old Jan 28, 2007 | 11:01 PM
baddog671's Avatar
baddog671
Nonsense, I used the screwdriver tip and a hammer to get mine off
Yea, dont taker any chances on explosions..
Old Jan 28, 2007 | 11:07 PM
Mustang Dad's Avatar
Mustang Dad
Something that works better than a block of wood or screwdriver, and something every mechanic should have in his tool box.....a brass drift. It's metal and wont chip like wood will, but wont spark like a steel screwdriver either.
Old Jan 28, 2007 | 11:11 PM
Cogtx's Avatar
Cogtx
ORIGINAL: Mustang Dad
Thanx for giving that toola name...now I can use that term to find one on ebay!!!
Old Jan 28, 2007 | 11:14 PM
baddog671's Avatar
baddog671
We are all poor mustang enthusiasts, a block of wood or screwdriver will do
Brass doesnt spark?
Old Jan 29, 2007 | 12:21 AM
Mustang Dad
OK...sorry about this before I start....gonna use some big words. Brass is a non-ferrous metal, i.e. it doesnt contain any iron. Iron is what causes sparks. And you can go down to Lowes or Home Depot and pick up a piece of brass round stock, 6-8 inches long for a bout 2 bucks.
Old Jan 29, 2007 | 12:30 AM
baddog671's Avatar
baddog671
I thought all metals sparked if you hit them right...damn, im getting smarter
Old Jan 29, 2007 | 12:33 AM
baddog671's Avatar
baddog671
Anyways, back on subject..
Its smart to just get a tank kit. This should come with the tank, sending unit, rings, filler hose, and clamps..right now i saw one on ebay for 99 bucks.USA made!
