Heaters
Old Jan 30, 2007 | 10:39 PM
KS68STANG's Avatar
KS68STANG
Default Heaters
This is probably a stupid thing to ask about considing the heater is 40 years old. but is there anyway that a guy could improve the heating capablities on a 68 Coupe. Because to be quite frank my heater is worthless. it barely produces enough heat to defrost the windows. my car is equipt with A/C but clearly it is to advanced for me to operate properly. any ideas?
Old Jan 30, 2007 | 10:50 PM
JamesW's Avatar
JamesW
Default RE: Heaters
Replace your heater hoses and heater core. It's probably full of rust and junk. Check the elbow joint that screws into the intake that feeds the heater hose. It may be corroded also. While you have the heater core out, get a rebuild kit and rebuild the heater box. The new seals will help direct the hot air to the vents.
Properly operating, it should run you out the car on the coldest of days.
Old Jan 30, 2007 | 10:53 PM
gothand's Avatar
gothand
Default RE: Heaters
Besides the heater box and core that James mentioned, make sure you have a correct, working thermostat. If it is stuck open or too low, the coolant won't get hot enough. BTDT with my Jeep.
Old Jan 31, 2007 | 12:25 AM
shr's Avatar
shr
Default RE: Heaters
+1 on the heater core! on my old stang it was the same thing and i pulled it out and it barley even had flow when i put the garden hose on it.
Old Jan 31, 2007 | 12:57 AM
stanging's Avatar
stanging
Default RE: Heaters
Also if it's factory air, make sure all vacuum lines are in good shape and the diaphragms are working properly.
Old Jan 31, 2007 | 01:04 AM
6mustang6's Avatar
6mustang6
Default RE: Heaters
Im having the same problem right now. I suspect the thermostat is stuck open or something. However in the summer the car almost overheats, and the winter it doesn't get hot enough at all. I stuck a piece of cardboard in the front of the radiator for a temperory heat solution.
Old Jan 31, 2007 | 06:44 AM
MidNite27's Avatar
MidNite27
Default RE: Heaters
What are the steps of removing and reinstalling a heater core on a 69? My heater core is on the way.
Old Jan 31, 2007 | 10:54 AM
sxs191's Avatar
sxs191
Default RE: Heaters
I just replaced the heater hoses and heater core on my 68 coupe. Here are a couple things I found wrong while doing it. The heater/defroster plenum wasn't securly connected to the heater box so air wasn't being directed properly. The heater hose elbow on the manifold was so old and rusted that when I pulled the hose off of it it was crushed inside from over tightning the clamp so it could barely pass water through. The seal's were mostly all gone. Mustangs Unlimited sells a whole rebuild kit (minus the Heater box assembly and fan) for $65.00. Part # 18502KIT
Old Jan 31, 2007 | 11:17 AM
grruminator78's Avatar
grruminator78
Default RE: Heaters
I was about to say when my heater gets going, it's great. hell you could put a cup of water on the dash and instant sauna! Now the A/C, lots of problems could have happened. Didn't even notice my condesor was brocken until I tried to work a horn issue. The connector snapped off at the condensor. ehh, but I'm switching to 134 anyway so all new stuff for a/c.
Old Jan 31, 2007 | 11:23 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Heaters
ORIGINAL: MidNite27
I have that info in the FAQ.
