off idle hesitation
Make sure the accelerator pump cam is properly adjusted as well. The screw with a spring is for this adjustability. I adjust mine so that there is basically zero clearance between the screw and cam, but with no pressure on the accelerator pump lever.
If that doesn't help, you may want to try a different cam for the accelerator pump. Try a richer cam and see if it helps or makes it worse.
yeah
every post i have read about this probklem says that it needs more fuel going in
i may pull the nozzle and try a bigger one
and then the cam
its a tiny thing that i should just probably just give to a proand be done with it
car runs to well for it to be something big
starts right up
idles fine
no smoking, missing, or knocking
so we will see
and then the cam
starts right up
idles fine
so we will see
ok maybe i found it
i was looking at my service manual
and noticed that the vacuum lines were wrong
it has that thermal vacuum thingy that screws into the intake
well anyway
the book says that the retard nipple gets manifold vacuum
the carb hooks to the thermal thing and then the thermal thing hooks to the vacuum advance
its hard to describe but if you look in your manual under 289/302 automatic it now looks like that
it instantly retarded the timing from 8 degrees BTDC to about 3 ATDC
but as soon as you push the gas it advances
havent had a chance to test it but it does start a little easier so hopefully tomorrow i can get it out for a full on test drive
oh and i have heard about putting the screw into the secondaries before but wasnt sure where to put it inside the slot
did you put the screw in so that the secondaries opened up immediatly or only made contact when the throttle was all the way open
well anyway
well test drive went well
i did two tests
the first was with the vacuum lines hooked up the way the book says and the retard (dizzy not driver) hooked up
ran well hesitation was much better
test two was with the retard completely unhooked and the nipples capped off
ran even better and even has enough power to spin the tire at takeoff again
timing with retard hooked up at idle was atdc
timing with retard unhooked and advance (port vacuum) is 10btdc
hopefully this is the final fine tuning needed
i am going to start saving up for the gt40p and tri Y header swap
still curious about putting in the screw on the secondaries to make it mechanical
all the way up so the back 2 open with the front immediatly
or at the bottom so the secondaires open at wot
or somewhere in the middle
i did two tests
ORIGINAL: baxsom
thats what i thought
i knew that mechanical secondaries have two pumps to give the extra fuel needed but a guy a few posts up said that he did this and it worked well
so i just wanted to make sure this was not a good idea
i have ran across so much conflicting info its hard to keep it all straight
Dont install gt40p heads until you check to see if the headers fit.The spark plug angle is different with the p heads.You may find the spark plug too close to the header.I had this problem with my 70 mustang 302.I didnt try the tri y headers but I would strongly caution you to test fit your combination.Also be aware that these heads were made for a roller cam and the springs are so strong they will eat your hydraulic cam and pushrods.$90.springs will remedy this.
