Carb Options
Old Feb 2, 2007 | 02:29 AM
6t9 stang's Avatar
6t9 stang
Default Carb Options
I am interested in buying a new carb. I will not ask for opinions on brands, because i know i will get 20 different answers. However, i will ask as to what size you think i should run.
Old Feb 2, 2007 | 02:36 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: Carb Options
650-750 cfm
Old Feb 2, 2007 | 02:41 AM
68SCode4speed's Avatar
68SCode4speed
http://www.ponycarburetors.com/defau...calculatingcfm
Here's some good info for you and might help you in making your decision...
(But- I'd put a Autolite 4100 with 1.12 primaries on it... )
Old Feb 2, 2007 | 02:43 AM
Colorado_Mustang's Avatar
Colorado_Mustang
600-650 for a decent 302.
Old Feb 2, 2007 | 02:09 PM
THUMPIN455's Avatar
THUMPIN455
Your engine could use a 750 vacuum secondary carb, but it will drive better and probably make a little more bottom end power with the 600-650. Dont run a mechanical secondary carb.. for Fords I like Holley, the 4100, and Demons. All of my Fords have Holleys on them, unless they are EFI..
Old Feb 2, 2007 | 02:16 PM
my77stang's Avatar
my77stang
+1 for 600-650 vacuum secondaries
BG road demon / speed demons ftw!
Old Feb 2, 2007 | 09:15 PM
6t9 stang's Avatar
6t9 stang
thats what i thought also, however, the Edelbrock tech recommended a 750 with the new RPM heads. Choices, choices.... whos advice to follow.
Old Feb 2, 2007 | 11:29 PM
my77stang's Avatar
my77stang
750 really IS too big for a n/a 302 - straight up, no bull
Old Feb 3, 2007 | 03:33 AM
Colorado_Mustang
CFM=((RPM*CID)/3456)*VE
I generally assume 100% VE, even though you're not likely to get there with most engines.
IMO, double pumpers are easier to tune in than a vacuum secondary carb, and will need less seasonal maintainance to deal with air density changes.
Old Feb 3, 2007 | 06:52 AM
Soaring's Avatar
Soaring
I ♥ Acer
What's wrong with the 600 cfm you already have on it?
