1970 engine options, 460?
Old Feb 2, 2007 | 09:32 PM
scottschall's Avatar
scottschall
Default 1970 engine options, 460?
Hello: Im new to mustangs, so lots of ?
Can i bolt a 460 big block type motorinto a 1970 mach 1using the 351 motor mounts and trans mounts that came in the car?
If not, what to get?
Old Feb 2, 2007 | 11:30 PM
my77stang's Avatar
my77stang
Default RE: 1970 engine options, 460?
i wish i had an answer for you (someone here will tell you what you need to know)
but welcome to the forums!!!
Old Feb 2, 2007 | 11:44 PM
69FECoupe's Avatar
69FECoupe
Yes it will fit. No it won't bolt in with the 351 chassis and tranny mounts. You'll need conversion engine mounts and a C6 ( the 351 came with an FMX) tranny mount. It's a real tight fit.
Old Feb 3, 2007 | 03:31 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Tight, as it massaging the shock towers will likely be necessary.
You'd be better off trying to find an FE series big-block or stroking the 351W.
Old Feb 3, 2007 | 07:37 AM
andrewmp6's Avatar
andrewmp6
if you get a man o war block from world you can have a 460 small block less work same power
Old Feb 3, 2007 | 10:20 AM
rwh129's Avatar
rwh129
I think you could use engine motor mounts from a 427, 428, or429,defenitely from 460.
Try a local junkyard, look for an old lincoln.
Old Feb 3, 2007 | 10:52 AM
my77stang's Avatar
my77stang
429/460 is the same dimensions and honestly a 429 is a better motor - shorter stroke big blocks kick ***
Old Feb 3, 2007 | 11:57 AM
tarafied1's Avatar
tarafied1
I have a 1970 429 in my 67. The FMX crossmember is the same as the C6 and a standard C6 mount will fit. I have Upper motor mount from a 70 Torino but the lowers are custom made. The headers also are custom made. I bought both from Peiorge.
[IMG]local://upfiles/56180/439D4C3E16EF4634A1F8111337DAD845.jpg[/IMG]
[IMG]local://upfiles/56180/4FB5453FE63C4941A598FC1917EAEA2A.jpg[/IMG]
[IMG]local://upfiles/56180/4AFF0672264C4A6EA6A13A4A3B2989BC.jpg[/IMG]
[IMG]local://upfiles/56180/90495E55F0A544BB80F07D6E9C65EEFD.jpg[/IMG]
Old Feb 3, 2007 | 12:08 PM
my77stang's Avatar
my77stang
thoes headers are badass!
Old Feb 3, 2007 | 12:56 PM
tarafied1's Avatar
tarafied1
ORIGINAL: my77stang
and real pain to install! each tube is equal length so they run all over under there...
Nick Oliver
Oct 17, 2018 04:22 AM
mungodrums
Oct 7, 2015 04:01 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Roush05
Sep 10, 2015 12:23 PM
Sep 1, 2015 08:16 PM
