Airbags????
was talking with a buddy and he was telling me i need to tighten up my body with frame extenders and traction bars and i wanted to hear some other opinions about ones to get and if it is worth it to get airbags and if so which ones...... i have a 66coupe
subframe connectors(frame extensions) are a good idea ties the front sub frame to the rear the shelby traction bars are a good idea i would check out www.laurelmountainmustang.com they have great deals on suspension rebuild kits for a stock to mild build and then maybe a little more performance something like the grab a track suspension from www.mustangsplus.com u can get them stiffer softer lowering,raising etc
and then all out id check in to www.opentracker.com (i think it is not sure on the addy) or www.streetortrack.com
Air ride technologies has a set up you can use, not cheap but really cool
http://www.ridetech.com/wizard/results.asp
I had "airbags" for my mustang I could pump them up for more rake or let air out to lower the rear. They worked well. I got rid of them with I did a complete suspension overhaul with KYB gas ajust all the way around, big sway bars, lowing spring and lower leaf springs, Global west a arms and struts. The works. Sticks real good now.
Gun
Gun
