Brake line size?
Old Feb 8, 2007 | 02:01 AM
ford65stang's Avatar
ford65stang
Default Brake line size?
I checked the FAQ section before i posted.......I didn't see the question nor the answer.
My question is.......im running new brake lines to the front and rear of the car.....and curious on what size of brake line is it ?
2nd question.......i have new disc brakes up front and normal drums in the rear.....Would you BEND the lines yourself ? or BUY them pre-formed ?
Old Feb 8, 2007 | 05:05 AM
70coupe's Avatar
70coupe
Default RE: Brake line size?
mustangs unlimited has line kits preformed
Old Feb 8, 2007 | 02:27 PM
66JameStang's Avatar
66JameStang
Bending the lines are not that hard it really depends on what you want.
The same size as the stock lines would be fine it really comes down to what fittings you will need for the ends and how good you are at flaring.
The size of the lines will just affect the amount of fluid you have to put in and how much you will have to bleed the lines. the preasure will be the same.
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
NorthAmericanTuning
Nov 9, 2016 11:44 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
squishbang
Sep 7, 2015 07:57 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
