HELP!! Starters are getting chewed up!
Old Oct 18, 2004 | 07:22 PM
monorailengineer's Avatar
monorailengineer
Default HELP!! Starters are getting chewed up!
Has this happend to anybody else and how do I fix it? I started the car one morning and It sounded like I had rocks banging inside my engine compartment. I shut the engine off and tried to start the car again. The starter wouldn't work after that. So I pulled the starter and it was all messed up. The gear had alot of grinding marks on it and missing teeth. This thing got chewed alive by the fly wheel. I got a new starter and installed it. I then started the engine and the same thing! Clank, Clank, Clank!!! I pulled the starter again and it looks like this one is getting messed up too. Does anybody know what it is? Do I need to replace the fly wheel?
Old Oct 19, 2004 | 12:47 PM
horseshoeing's Avatar
horseshoeing
Default RE: HELP!! Starters are getting chewed up!
Just a guess, I would look at the fly wheel. Where do you get the starter? Maybe you got a bad starter. Do you have a auto or a stick?
Old Oct 19, 2004 | 12:52 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Either some teeth are broken off the flywheel or the starter needs some shims or shims removed.
Old Oct 20, 2004 | 02:30 AM
monorailengineer
I got the starter at Pep Boys. Its nothing special. I paided $40 bucks for it. What are shims? Washers????
Old Oct 20, 2004 | 08:29 AM
horseshoeing
Pep boys sell junk. Goto a starter shop.
Old Oct 20, 2004 | 01:48 PM
quig's Avatar
quig
Sounds like the solenoid is sticking
Old Oct 20, 2004 | 01:51 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
or the starter needs to be shimmed
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
logan409
Sep 26, 2015 07:43 PM
jaiidutch
Sep 14, 2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
