head lights
Old Feb 11, 2007 | 07:58 PM
retrokix's Avatar
retrokix
Default head lights
hey, alright i have a 65 coupe
and for some reason my headlights flicker
the werid thing is that they go for about 15-30 mins striaght with no problem
and then they start to flicker
any idea what i should look at??
Old Feb 11, 2007 | 08:01 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: head lights
Most likely you have some ground wires that are needing a good cleaning. We also have an article in the FAQ about how to improve the brightness of your headlights.
Old Feb 11, 2007 | 08:04 PM
retrokix's Avatar
retrokix
aight thanks the brightness is good
but its just that they flicker on and off
Old Feb 11, 2007 | 08:57 PM
Wayne67vert's Avatar
Wayne67vert
Change the headlight switch. It has an internalcircuit breaker that is going bad.
Old Feb 11, 2007 | 10:58 PM
LCC's Avatar
LCC
Does your car start ok? almost sounds like the battery is drained so far that your seeing the flicker of the regulator? When you start getting the flicker, is it a steady rate or does it go up and down with the rpms?
Old Feb 11, 2007 | 11:09 PM
mustanglover66's Avatar
mustanglover66
check the grounds at the headlights first, 9 times out of 10 thats the problem
Old Feb 11, 2007 | 11:18 PM
retrokix's Avatar
retrokix
naw my car runs fine and my batterys good
im thinking the ground wires might be it
so ima check that out tomorrow after school and let you know how that goes
thanks alot guys :]
Old Feb 12, 2007 | 01:38 AM
JamesW's Avatar
JamesW
+1 on your headlight switch going bad.
While you're at it... do my headlight relay mod. See the FAQs
Old Feb 14, 2007 | 01:22 AM
retrokix's Avatar
retrokix
ok so i checked my grounds and cleaned them
but nothing they still flicker
next step is headlight switch
hmm any help or ideas?
how to start this one?
Old Feb 14, 2007 | 01:58 AM
superdavid's Avatar
superdavid
Betcha $20 its the headlight switch. I've been there before several times. You can disassemble it and clean it but it will do the same thing again in about a month, so you're better off picking one up at your local strore for no more than $30...
