I'm new here with a question
Old Oct 20, 2004 | 11:31 AM
thundermist's Avatar
thundermist
Default I'm new here with a question
Hello, I'm new here and I have a 69 fastback with 302. I've spent the last four years restoring it and I am finally seeing the light at the end of the tunnel!!! I wonder if anyone experiences the same thing however, I installed a new gas tank and I am pretty sure I installed it correctly...However when I open the truck, I always smell fuel oder!
Also, my fastback is NOT a fold-down! With that I have come up empty in being able to find the proper parts for around the back seat. Does anyone have any ideas?
Thanks!!!!!
Old Oct 21, 2004 | 11:49 AM
horseshoeing's Avatar
horseshoeing
Default RE: I'm new here with a question
How does the tank work? Is it like a 66? Could it be a gasket? Maybe a new fuel cap. Did you poke a hole in it?
Old Oct 22, 2004 | 07:57 PM
rwcstang's Avatar
rwcstang
also check the fuel lines...maybe sumthing is leaking, i would look inside or outside the tank also start the car and see if u see leakage or u start to smell it.......
[IMG]local://upfiles/6730/7F2578CE4AAF4DFA9430C8DBEE86F5E6.jpg[/IMG]
Old Oct 25, 2004 | 03:04 PM
thundermist
No I have not found any leaks! That's the weard part of it! It's a new tank and lines! No leaks just fumes!
Old Oct 27, 2004 | 11:13 AM
horseshoeing
Get a match. No, no, no, don't do that. I was just joking. Maybe use your nose. Sniff to find the leak. Try not to get a head rush. Use you kid for this job or you wife. Just joking on that to. You have a leak. It may be a gas vaper leak. Could it leak when you put gas in it?
Old Oct 30, 2004 | 12:55 PM
Soaring's Avatar
Soaring
I ♥ Acer
First check the gasket on the sending unit. Then make sure the cap is ventilating. You have to have a leak somewhere....keep looking.
Old Nov 4, 2004 | 02:20 PM
bob emmerich's Avatar
bob emmerich
Check around the filler pipe opening for vapor leak. Also make sure the cap gasket is not rotted/cracked/broken.
Old Nov 4, 2004 | 06:11 PM
vfast's Avatar
vfast
I ♥ Acer
so what did ya find out?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
