Granada brake swap question.
Old Feb 15, 2007 | 10:55 PM
racerss's Avatar
racerss
Default Granada brake swap question.
As I have stated before.....im posting for a friend who has a '70 Fastback...He was wondering if anyone has had any experiance with this brake kit http://www.discbrakeswap.com/and if they have was it good or bad.....the price seems great!
Old Feb 15, 2007 | 11:32 PM
edawg17's Avatar
edawg17
Default RE: Granada brake swap question.
I installed it and haven't had any problems. It comes with very detailed instructions and goes on relatively easy. It seems to be well worth the money. Can't beat that price for front discs.
Old Feb 15, 2007 | 11:41 PM
baddog671's Avatar
baddog671
Dont mean to steal this thread but its related so perhaps someone can help. I already have front disc but it all needs replaced. Whats the difference between replacing it all with the oem style stuff, or the Granada swap? Ive heard alot about it and it seems cheaper, so whats the drawback?
I might just dissamble, clean the spindles, and replace everything with oem style from a local store. Assembly shouldnt be a problem...
Old Feb 16, 2007 | 02:48 AM
connor90's Avatar
connor90
i ordered mine from that guy and while i have yet to actually try my brakes out (still have to get some little things done) i had a great experience ordering from that guy and wouldn't hesitate to reccomend him to anyone.
Old Feb 16, 2007 | 04:55 AM
DenDen's Avatar
DenDen
What about the vacuum diaphram.the big granada part is too big for the 70 mustang.
Old Feb 16, 2007 | 02:15 PM
degins's Avatar
degins
ORIGINAL: DenDen
If you are speaking of the power brake booster, that part is not included with the kit. If you want power brakes on a 1970, use the 70 type booster and power type pedal with the master cylinderincluded with the kit. Just specifypower brake type when ordering.
Old Feb 16, 2007 | 02:25 PM
degins's Avatar
degins
ORIGINAL: baddog671
It depends on what yearMustang you have. Rebuilding your current system is likely to beless expensive if you can reuse spindles, bearing, hoses, hardware, tie rods. If not it would cost about the same.
Old Feb 16, 2007 | 02:37 PM
kalli's Avatar
kalli
degins: Granada disk break swap only possible for 5 lug wheels ?
Do I have this right ?
Kalli
Old Feb 16, 2007 | 03:45 PM
mikethebike's Avatar
mikethebike
Yes....only with 5-lug rotors. Then you just put an 8-in rear axle from a v-8 car and you are done. If I install the IRS from Heidt's in my 65 I'll even sell you the stock 4-piston Kelsey-Hayes front brakes and the 3.25/1 rear axle for a good price.How about the Global west modified front suspension with Koni, Quickor and export/monti-carlo and Traction-Master under-rides for a very good price?
Old Feb 16, 2007 | 04:05 PM
baddog671's Avatar
baddog671
ORIGINAL: degins
ORIGINAL: baddog671
Spindles would be reused and tierods are already new, so i would just need everything past the spindles, if that makes sense..
