t-5 conversion
Old Feb 16, 2007 | 12:01 AM
EmperorOfChicken's Avatar
EmperorOfChicken
Default t-5 conversion
okay guys, so as some of you may know, I've been speculating putting a manual transmition into my 65 coupe. right now its got a c4 with a shift kit, which is fun and all, but there is nothin better to me than a manual tranny in a mustang. I've found a few t-5 (more rear end gear choice from what ive heard because of the 5 speeds, and then easier for highway driving) what all would be required for the swap. clutch, flywheel, yadda yadda yadda, i need to know so ican calculate value and start searching for parts in a serious manner, i now have the money available and am more serious than i have been before. http://cgi.ebay.com/ebaymotors/T-5-m...QQcmdZViewItem here is a tranny i found online. what would have to go with somethin like that to make it work with my 289? thanks guys!
Old Feb 16, 2007 | 12:18 AM
67Sally's Avatar
67Sally
Default RE: t-5 conversion
It's not that hard at all...you don't need to swap much. What are you going to do with the shift kit? I may want it.
Here's a link I have saved that I thought was pretty good.
Old Feb 16, 2007 | 12:29 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
check out mustang steves page www.mustangsteve.com i believe he has a late model type pedal swap available ull need the pedals,clutch linkage(either cable or vintage setup)a flywheel,pilot bearing,shifter(to protect the t5 from over shifting(leading cause of t5 failure) and the d/s shortened about 1"
Old Feb 16, 2007 | 12:36 AM
joe68stang's Avatar
joe68stang
The buy it now price seems a bit high for a used unit. I have seen rebuilt T5's on e-bay for about the same price. I picked up a used one with a '92 bellhousing and shifter for 500.00 . Joe
Old Feb 16, 2007 | 01:41 AM
JamesW's Avatar
JamesW
That's the wrong transmission for what you need. You don't want a V-6 unit. You want a V-8 unit out of a 89-92 series.
Use this to match the trans to your horsepower requirement.
http://www.therangerstation.com/tech_library/T5ID.htm
Given, that you were to start with that...you'd need:
- modified drive shaft
- T-5 output yoke
- Adapter trans lower bracket
- Clutch mechanism (hydraulic or cable)
- Bellhousing
- Clutch, Pressure plate, throwout bearing, clutch arm
- Clutch pedal
Old Feb 16, 2007 | 09:27 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
that v6 will work just fine its only rated at a few ft lbs torque capcity less than a v8
Old Feb 16, 2007 | 10:01 PM
JamesW's Avatar
JamesW
If you're going to spend the money, get one rated for 300+ HP.
Old Feb 16, 2007 | 10:11 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the v6 tranny is the same as the pre 1986v8 trannys the leading cause of t5 failure is overextending the shift rails and i dont think hes gonna hook up really hard so it should be fine esp if he picks it up for 162$ starting bid heck i might bid on it[8D] i need one for the 65 instead of the toploader
Old Feb 17, 2007 | 12:32 AM
Yonco's Avatar
Yonco
Im doing a t-5 swap and the only problem im having is the clutch pedal. i dotn have a stock one and im looking on ebay for one. Im thinking of going hydraulic, Anyone know of a slave cyl that will work on t-5? -Jon
Old Feb 17, 2007 | 12:59 AM
JamesW's Avatar
JamesW
Check this out on do it yourself hydraulic clutch
http://midnightdsigns.com/Mustang/HYD%20Clutch.htm
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
DCole24
Sep 11, 2015 10:50 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
